1991 brougham wont charge battery. Both new alt, battery
Results 1 to 10 of 10
Like Tree3Likes
  • 2 Post By danksourd
  • 1 Post By danksourd
1985-1996 Fleetwood and Brougham Forum Discussion, 1991 brougham wont charge battery. Both new alt, battery in Past Cadillac Vehicle Discussion; Ive replaced the alternator battery n still to my prevail same problem died battery. Ive had both tested at numerous ...
    danksourd is offline Cadillac Owners Member
    Automobile(s): 1991 Cadillac Brougham
    Oct 2013
    29
    5
    Ive replaced the alternator battery n still to my prevail same problem died battery. Ive had both tested at numerous part shops to make sure they were good n both worked in shop also in my fathers car but not in mine. Wires dont look bad to me put dont know wat else to do im lost. HELP PLZ only means to work an if not fixd by monday morning may not have job to go back too
    Sent from AutoGuide.com Free App
    Feb 2003
    california
    69
    6,680
    Re: 1991 brougham wont charge battery. Both new alt, battery
    The fattest wire on the alternator should have voltage at all times from the battery. I think that wire is broken somewhere from the starter to the alternator or a fusible link is melted. Battery power comes from the battery, down to the starter solenoid then is distributed to other circuits. You need the car towed to a shop that can fault trace the wiring harness.
    YoshiMan's Avatar
    YoshiMan is offline Cadillac Owners Fanatic
    Automobile(s): 1975 Coupe Deville D'Elegance
    Oct 2012
    Denver, CO
    32
    261
    Any problems with the fuses?
    Oct 2013
    29
    5
    All fuses are good. Checking terminal wires tomorrow post wat happens then
    Oct 2013
    29
    5
    Alternator is not geting any power to it at all
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,614
    On the small two wire terminal, one side gets power from the battery, the other side gets power from a fuse under the dash. Is the charge light on when running? When you turn the key to run(but not starting it) does the charge light come on? If you are not getting power to both little wires then you either have a bad fuse, bad "no charge" bulb or a broken wire from the fuse box to the alternator.
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    Someone mentioned fusable links. I happen to have photos of mine on my 472 when I got it. They had melted from being too close to the exhaust, not from a short. I got replacements from auto parts store.
    Just make sure yours don't look like this!
    photo uploading
    Oct 2013
    29
    5
    It turned out to b that the ac fuse was missing so I
    Replacced it with a 20 fuse n bam that bitch charges. Thanks everyone for the help
    csbuckn and talismandave like this.
    Mar 2012
    Madison WI
    57
    7,893
    Glad you found a simple fix! In time to save your employment even!
    Oct 2013
    29
    5
    Hell ya me too
    talismandave likes this.
  13. Remove Advertisements
