1980 cadillac fleetwood coolant sensor ????
Results 1 to 8 of 8
1985-1996 Fleetwood and Brougham Forum Discussion, 1980 cadillac fleetwood coolant sensor ???? in Past Cadillac Vehicle Discussion; Hi guys, i have a problem with my fleetwood Since 1 month, the "STOP ENGINES TEMP" light run on the ...
    CORNE DE BRUME's Avatar
    CORNE DE BRUME is offline Cadillac Owners Member
    Automobile(s): 1980-FLEETWOOD BROUGHAM
    Aug 2012
    FRANCE
    55
    85
    Smile1980 cadillac fleetwood coolant sensor ????
    Since 1 month, the "STOP ENGINES TEMP" light run on the dashboard ??
    When i put the key on the car, the light is OK .
    When the engine run, the same light run again, but low ?
    Have you an idea ?
    On the top of the engine, i see a sensor with a wire. When i Unplug the wire, i have the same problem...... the light run again on the dashboard.
    Thank for your help
    Didier from France
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: 1980 cadillac fleetwood coolant sensor ????
    Does your horn work? My memory is foggy but I think I had that light on for years in my Seville until I replaced the horn relay.
    SafariOne is offline Cadillac Owners Fanatic
    Automobile(s): 1981Cadillac Fleetwood Brougham D'Elegance Coupe m
    Mar 2008
    British Columbia
    392
    When you run the diagnostic codes does the temp. sensor code come up?? If you are changing the temp. sensor the manual will say you need a special tool, but I found that a flex head gear wrench did the trick... other wise you will be forever getting that puppy out of there.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    The "STOP ENGINE TEMP" light comes on if the key is in the ignition ( engine off) and the drivers door is opened. I would suspect a faulty door jamb switch. The same switch that turns on the dome lights when you open the door!
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    40
    1,150
    Quote Originally Posted by SafariOne View Post
    You can't run diagnostic codes on this year Caddy.
    Aug 2012
    FRANCE
    55
    85
    Hello to all
    Thank you for your messages.
    I cleaned the water cooler of the car because the water was black and the color of rust.
    Since the lamp does not light up on the dashboard.
    Can you help me and tell me where is the temperature sensor on the engine (picture ?).
    thank you
    1980coupe's Avatar
    Jan 2009
    El Paso, TX
    40
    1,150
    follow the coolant hose where it leads to the engine and just below that you'll see the wires leading to it. I would scan an image but cannot locate my book right now, lol.
    Aug 2012
    FRANCE
    55
    85
    Hi
    Thinks for your help
  11. Remove Advertisements
