vacuum question
Results 1 to 3 of 3
1985-1996 Fleetwood and Brougham Forum Discussion, vacuum question in Past Cadillac Vehicle Discussion; 1990 Brougham. Is the vacuum system a closed system? Is a leak anywhere a leak everywhere? ohio boy...
    ohio boy is offline Cadillac Owners Member
    Automobile(s): 1990 brougham
    Jul 2012
    66
    43
    vacuum question
    ohio boy
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,612
    Olds 307? A leak at the back of the intake manifold will be a leak everywhere. I believe there are three different vacuum systems in the car but they all need a steady manifold vacuum. I believe emissions, hvac and engine accessories are all separate from each other. I could be wrong, emissions and accessories could be together.
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Re: vacuum question
    On the 307, the emission controls system is tied into accessories like the ILC and vacuum brakes; the ILC helps stabilize the engine idle when the A/C compressor or alternator is causing a strain, and the vacuum brakes prevent engine run-on (dieseling) when the engine is turned off. The cruise control is mostly a stand alone system, but its vacuum source is spiced into the line going to the vapor canister.
    Basically, if you have a leak anywhere in the system, it will cause some decrease in performance. Also, if you have a leak in the system, you can be almost guaranteed that there is another leak somewhere else, and you should just replace all the vacuum lines.
    Here is a vacuum diagram:
