1992 Brougham radio problem
Results 1 to 8 of 8
1985-1996 Fleetwood and Brougham Forum Discussion, 1992 Brougham radio problem in Past Cadillac Vehicle Discussion; Hi all.Just bought this car but can't get the radio or antenna to work. Have checked all of the fuses ...
    welkiemike is offline Cadillac Owners Member
    Automobile(s): 92 Brougham
    Sep 2013
    7
    Hi all.Just bought this car but can't get the radio or antenna to work. Have checked all of the fuses and they all look good.Also the map lights above the rear view ,
    mirror won't work ,as well and don't know if it could be related.Any help would be
    greatly appreciated.
    Thanks ;
    Mike
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by welkiemike View Post
    Thanks ;
    Mike
    For the map lights, remove the one screw that holds it in place, drop down the map light holder, and see if the ground is not connected. Also, see if the light bulbs are burnt out.
    Also, does anything else in the car not work? Sometimes a fuse can look ok, but be blown.
    Sep 2013
    7
    Re: 1992 Brougham radio problem
    Hi and thanks. Everything else works other than the map lights and radio/ antenna. The fuel gauge is
    screwy but I believe that's due do a bad sending unit.I don't know what it could be. I don't want to go to anafter market radio, but may not have a choice.
    Mike
    Feb 2003
    california
    69
    6,663
    What does 'look good" mean? You did check all the fuses with a test light with the key in the ON position, right? The radio has 2 fuses, one on a switched on hot circuit and another on a constant hot fuse to retain station memory. The owners manual should point you to the right 2 fuses. Usually yellow 20 amp ones.
    Dec 2010
    St. Louis, MO
    6,395
    do you have a test light or multimeter? I'd check for power at the radio. If it is not working at all, I'd suspect it might not be getting power.
    Sep 2013
    7
    I just physically removed and looked at the fuses. I need to aquire another test light as mine was lost.
    When I initially started to trouble shoot, I noticed the 10 amp radio fuse was completely gone. I put one in , but still nothing.
    I then pulled the dash apart, and found both plugs disconnected from the radio.Put them back on, but still nothing ,other than the buttons now light up with the dash lights.
    Mike
    Dec 2010
    St. Louis, MO
    6,395
    Mike
    The back lights may be on a seperate circuit
    Btw, installing something electronic to a plug that has power can blow the fuse.
    Sep 2013
    7
    Thanks. What I'm going to have to do is get another test light and
    see if I actually have power going to the radio.
    Mike
  11. Remove Advertisements
