I Found a possibly missing vaccuum hose?
Results 1 to 7 of 7
1985-1996 Fleetwood and Brougham Forum Discussion, I Found a possibly missing vaccuum hose? in Past Cadillac Vehicle Discussion; Here i've found two sealed pipes which looks to be vacuum pipes. One in a vacuum hose branching sitting on ...
    Jeppi94's Avatar
    Jeppi94 is offline Cadillac Owners Fanatic
    Automobile(s): 1989 Cadllac Brougham
    Jul 2013
    Gothenburg, Sweden
    23
    173
    QuestionI Found a possibly missing vaccuum hose?
    Here i've found two sealed pipes which looks to be vacuum pipes. One in a vacuum hose branching sitting on teh EGR and one on what i believe is the idle throttle solenoid, is it possible there is a hose that's missing here?DSCN5058.JPGDSCN5062.JPGDSCN5063.JPG
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,620
    The one on the solenoid looking thing is supposed to be open. The other one is a vacuum break I believe. My guess is it goes to manifold vacuum. Calling Sven for your easy to read diagram.
    Jeppi94's Avatar
    Jul 2013
    Gothenburg, Sweden
    23
    173
    Re: I Found a possibly missing vaccuum hose?
    Ok, i removed the seal for the one on solenoid branch thing, i can feel a vacuum suction from the pipe, but removing the seal didn't affect the engines idle or performance. Now to something different, on the right side valve covers, there are a rubber cap over a hole down into the valve covers which has a hose that goes into the air filter intake, what's that?
    Jan 2008
    Minneapolis
    5,620
    Pcv? If you take it out and shake it, it should rattle.
    Quote Originally Posted by Jeppi94 View Post
    Actually, looking at this pic, the circle on the left goes to what I think is the vacuum break. Keeps the engine from dieseling after you turn it off. The circle on the right I was wrong about, not should where it's suppose to go.
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    You are missing a vacuum line...
    The solenoid is supposed to be connected to the Knock Sensor, and the thing is the VRV valve, which is supposed to have an open port (an a foam filter on the end).
    The valve on the right side is the PCV valve, and there should be a similar sized tube coming from air cleaner and going to the left side valve cover. These are are for the Positive Crankcase Ventilation system, so make sure both are connected.
    Jeppi94's Avatar
    Jul 2013
    Gothenburg, Sweden
    23
    173
    Thanks a lot for this diagram! I'm going to go out the first thing i do tomorrow when I've got daylight to investigate this! First I've got to locate the knock sensor
    sven914's Avatar
    Dec 2008
    4,256
    ^It's black and has a red electrical clip on it...
  10. Remove Advertisements
