De Carb Olds 307 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
1985-1996 Fleetwood and Brougham Forum Discussion, De Carb Olds 307 in Past Cadillac Vehicle Discussion; I have no clue if type F cleans any better or worse than Dexron. Dex-ron. I would not put trans ...
  1. #16
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: De Carb Olds 307
    I would not put trans fluid in the oil on a Cadillac engine. They typically have very minimal garbage in the bottom end compared to older stuff. The main and rod bearings might not like it.
  2. #17
    jamespowers is offline Cadillac Owners Connoisseur
    Automobile(s): 1986 Brougham, 1975 Eldorado, 2008 Escalade
    Mar 2013
    1,100
    Quote Originally Posted by The Ape Man View Post
    No clue if type F cleans any better or worse than Dexron. Dex-ron.
    I didn't use it in my Cadillac----it was a 59 Oldsmobile at that time.
  3. #18
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    I just added a half quart of Dexron to my last tank, and noticed an immediate change. The engine felt like it was missing at idle, and after driving it for a half hour with the ATF in the tank, the idle has almost completely smoothed out. Usually, fuel additives cause the engine to run worse until the tank is empty, so I would say that the Dexron is working better than anything commercially designed to improve engine performance.
