Removing A/C grilles & center trim plate...
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Jeppi94
1985-1996 Fleetwood and Brougham Forum Discussion, Removing A/C grilles & center trim plate... in Past Cadillac Vehicle Discussion; Hello! I'm putting back the original radio in my 89 brougham, but it looks like i have to put it ...
    Jeppi94's Avatar
    Jeppi94 is offline Cadillac Owners Fanatic
    Automobile(s): 1989 Cadllac Brougham
    Jul 2013
    Gothenburg, Sweden
    22
    158
    AngryRemoving A/C grilles & center trim plate...
    Hello!
    I'm putting back the original radio in my 89 brougham, but it looks like i have to put it in from the inside. However, i must remove the front trim panel. Then 2 problems appear, one screw...or nut (i can't see it) seems to hold the trim panel in place in the middle (between the air vents). Next problem, how do you remove the air vents without tool J-24612-01 (the tool is 225$...) ??
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,021
    Re: Removing A/C grilles & center trim plate...
    Very carefully. I always used a small flathead screwdriver to bend the tabs down a bit, one at a time, while slowly rocking them out the front of the dash. Takes time, but it works. Good luck on your project!
    Jeppi94's Avatar
    Jul 2013
    Gothenburg, Sweden
    22
    158
    Thx, it's all fixed now, so this post is not needed any longer, i just used my nails and fingers to remove the air vents...no need for a 225$ tool, it was really easy x) Anyhow, this is how it looks now! It's not all straight, but i will fix it up and connect the wires tomorrow when i got daylight!
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by Jeppi94 View Post
    <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=143337"/>
    Glad to see you got it in.
    Nice UX1 by the way ....is it from a chevy? (black buttons/ face)
    Jeppi94's Avatar
    Jul 2013
    Gothenburg, Sweden
    22
    158
    I bought it from Ebay, it's re built and got Aux now, so i can play music from my cellphone, or MP3. But i believe it was in a Cadillac Seville once.
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    39
    1,150
    Where did you see the tool for sale? On a website? I would prefer this over screwdrivers to pull out tabs. Takes too long.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,612
    Nice. Did it plug right in and mount in the same spot? Straight forward swap?
    Jeppi94's Avatar
    Jul 2013
    Gothenburg, Sweden
    22
    158
    I never saw the tool forsale myself, but on another Cadillac forum...i saw someone had a thread about this same question, and someone in there had bought tool J-24612-01 for 225$. But try to search the net, i've not seen it on Ebay yet.
    Jeppi94's Avatar
    Jul 2013
    Gothenburg, Sweden
    22
    158
    I had to remove some plastic covers that held up the other much smaller JVC radio, and i removed the plastic panel and AC grilles to be able to mount it from the inside, otherwise than that, it did fit perfectly in the old mounting dock!
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,388
    Good job, I like your projects and things you have done in your gorgeous car . I think we need to use AUX Adapters too given that cassette player is out of order and CD player sucks because it's aftermarket lol ,other than that only option is radio and it only tunes uneven numbers
    Jeppi94's Avatar
    Jul 2013
    Gothenburg, Sweden
    22
    158
    i Bought this radio re manufactured from Ebay, so everything on it still works...and yes, i do use cassettes a lot I buy new empty cassettes and put my favorite songs on My goal is to make my car as good as new...if not better. In the future, when i got the money (i'm just 19, have had my drivers license for a little bit more than a year :P ) i'm gonna take it all apart, blaster the paint and the little rust away (it's a Canada car...so it has a little rust) and have it painted in it's original Academy Gray metallic color (current paint job which is original is sprayed with scratches and such from the wintery Canadian roads. But my next project is to make the Opera lights work again. Now I've mostly focused on the engine, putting in new good oil, emptied the radiator and put new coolant in, and cleaned carb/throttle body, to make it "mechanically safe" so now at least i know that the engine is good for a few years
    77CDV likes this.
    1980coupe's Avatar
    Jan 2009
    El Paso, TX
    39
    1,150
    yup found the otehr website..
    http://forums.cadillaclasalleclub.or...?topic=93128.0
    guess screwdrivers it is
  15. Remove Advertisements
