Leak on passenger floor, 95 Fleetwood
Results 1 to 11 of 11
1985-1996 Fleetwood and Brougham Forum Discussion, Leak on passenger floor, 95 Fleetwood in Past Cadillac Vehicle Discussion; As I spend the weekend attending to all the little projects I've been saving up for, more little issues rear ...
    Cadillac Giovanni's Avatar
    Cadillac Giovanni is offline Cadillac Owners Enthusiast
    Automobile(s): 86 DeVille (RIP), 89 Brougham D'Elegance, 95 FWB
    May 2006
    Westport, MA
    31
    912
    As I spend the weekend attending to all the little projects I've been saving up for, more little issues rear their ugly heads.
    The floor on the front passenger side all the way up against the firewall is very wet. I can't remember the last time it rained, maybe last week, but there is quite a lot of water. Any ideas? Not really any rust on the car, so I'm trying to check for seals and stuff. Perhaps it's the AC evaporator drain hose? Trying to find it, but no luck...
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 FWB 81SDV 96 FWB 94 Fleetwood
    May 2003
    Massachusetts
    1,210
    Re: Leak on passenger floor, 95 Fleetwood
    Something is wrong with the A/C drain. I have changed the heater core and had a rubber drain piece fall out of position and the drain water did not make it out.. Its right under the heater core looking from under the hood.. Check to see if its there or blocked up...
    May 2006
    Westport, MA
    31
    912
    I've got a small plastic outlet below the heater core, to the left of the AC evaporator lines, but no hose attached. I think this is the culprit. Gotta see if I can find a hose for it somewhere...
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    8,026
    It's a 90 degree rubber elbow, pointing at the ground. If missing, use a piece of tubing, zip tie to the frame.
    May 2006
    Westport, MA
    31
    912
    That was it. Wish I'd found it before summer...
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,393
    Good to hear that, better than never although it was kinda late
    firstimecaddi is offline Awaiting Email Confirmation
    Automobile(s): 94 Seville; 95 FWB
    Apr 2006
    Out of my mind
    653
    I am having the same issue too. Right now the carpet and padding is wet. I took off the under dash plastics and ran the AC, the drain pan is catching the run off water. I do not have a rubber elbow on the outside though.
    Could it be a body seam leak?
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    Did the 80s B/C bodies have the same issue with the rubber elbow falling off?
    May 2006
    Westport, MA
    31
    912
    My 89 has over 200,000 miles and the hose is still firmly in place. My 95 had barely 30,000 when I bought it, and it was missing. Possible a previous owner replaced the hose on my 89 and used a very tight clamp or silicone to keep it there.
    Does the hose not have a clamp from the factory? Is it just kinda jammed on there? That's pretty weak.
    Sep 2006
    Ontario, Canada
    44
    8,026
    No clamp.
    firsttimecaddi, get something on the outlet pointing at the ground, the elbow stops your symptoms. A 90 degree spark plug boot will work.
    gplesh99 is offline Cadillac Owners Member
    Automobile(s): 1988 Fleetwood Brougham
    May 2013
    11
    Interesting. On my '88, it's just an open hole at the bottom of the evap. chamber out in the engine compartment.
  14. Remove Advertisements
