CARB Compliant - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Like Tree3Likes
1985-1996 Fleetwood and Brougham Forum Discussion, CARB Compliant in Past Cadillac Vehicle Discussion; Originally Posted by ferrisworld I have a 79 Deville that is federal emissions and it's been registered in CA for ...
  1. #16
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by ferrisworld View Post
    I have a 79 Deville that is federal emissions and it's been registered in CA for probably over 25 years (I've had it for 12), and it doesn't have any CA emissions stuff on it, just the federal stuff. I think the only major difference on it was the AIR pump. CA cars had it, federals didn't and mine still doesn't. I also have an aftermarket 3" cat that Ys out to duals from there on back. It's legal because the cat has an EO number from magnaflow, and you can do whatever you want after the cat as long as it's not too loud, so I wouldn't worry about your exhaust too much. Having it dump before the rear axle might raise their suspicions, but as long as the cat is there and it's a legal cat and it works, you should be fine.
    Dumping before the rear end will fail mechanical inspection, not emissions inspection. If you sit for too long, the exhaust will get up into the cabin and might cause you to suffocate.
  2. #17
    ferrisworld is offline Cadillac Owners Fanatic
    Automobile(s): 1979 Sedan Deville
    Feb 2005
    Sacramento, CA
    444
    Re: CARB Compliant
    I see, yeah that makes sense.
  3. #18
    gplesh99 is offline Cadillac Owners Member
    Automobile(s): 1988 Fleetwood Brougham
    May 2013
    11
    Re: CARB Compliant
    Glad I live in FLA!!!!!!
  5. #19
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Re: CARB Compliant
    Quote Originally Posted by cadillac kevin View Post
    I never thought about that...
  6. Remove Advertisements
