Results 1 to 8 of 8
Thread: Rear end noise
    bluegrill is offline Cadillac Owners Member
    Automobile(s): 1975 Coupe DeVille
    Oct 2012
    42
    Rear end noise
    I have a noise coming from the rear of my '75 Deville. It is a whine like gear whine. Sounds like the sound you get from a manual tranny in reverse. It starts out low in pitch and increases to a high pitch whine with speed. Definitely related only to vehicle speed. Above 55-60 mph it is barely aubile. So, I'm thinking differential. I opened the diff fill plug and stuck my pinky in just to make sure I had lube in there. The color and consistency of the lube in there looks an awful lot like Auto trans fluid. I've only had this car a few months. If someone had put ATF in the differential would it cause a whine like that? Would any damage likely have ocuured? Any opinions would be apreciated.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: Rear end noise
    Some rear axles use ATF. Maybe someone thought it would make the car get 30 MPG. If that's what you have in there change it A.S.A.P.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: Rear end noise
    ATF would not be good in there. I have never heard of anybody dumb enough to do this so I hope that's not the case. Gear oil is usually very thick and smells bad. This is why I always change fluids when I get a vehicle, just so I know what is in there.
  5. #4
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,985
    Re: Rear end noise
    ATF is nowhere near the viscosity needed for a rear. It should be 80W90 gear oil. Much thicker.
  6. #5
    Oct 2012
    42
    Re: Rear end noise
    O.K. great. Thanks for the replies. It can't hurt to change it even if I'm wrong. Any idea how much gear oil it takes to fill it up? I think I read some where 4 1/2 pints. Does that sound right?
  7. #6
    SafariOne is offline Cadillac Owners Fanatic
    Automobile(s): 1981Cadillac Fleetwood Brougham D'Elegance Coupe m
    Mar 2008
    British Columbia
    392
    Re: Rear end noise
    If you do have a rear problem it will most likely be the carrier bearing with a noise like that. Try the fluid first and if you still have the noise you can always recoupe the oil.
  8. #7
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: Rear end noise
    That red fluid could have been an industrial gear lube. In industrial applications where transfer drive units are used, they get their oil from specialty oil producers. They produce a wide selection of lubricants for various applications, from transfer units to bearing lubes, also greases for various applications also. Most of these lubes have a red dye added to identify them. Someone could have substituted one of these gear lubes for rear gear lube and it is most likely the wrong viscosity for the application. Save a dollar, pay more later.
  9. #8
    Sep 2006
    Ontario, Canada
    44
    7,985
    Re: Rear end noise
    You fill it until it comes out the fill hole.
  • You may not post replies
