Drum brake adjuster
Results 1 to 3 of 3
1985-1996 Fleetwood and Brougham Forum Discussion, Drum brake adjuster in Past Cadillac Vehicle Discussion; Intermittent ABS code 33 eventually made me take one of the drums off. Sure, the wheel speed sensor was covered ...
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,112
    Drum brake adjuster
    Intermittent ABS code 33 eventually made me take one of the drums off. Sure, the wheel speed sensor was covered with thick layer of gunk. Cleaned it up. Also noticed that the upper corner of the primary shoe was worn excessively. The adjuster appeared to be frozen. I hate these drum brakes...
    Is anti seize lube good for the adjuster after I clean it up?
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,164
    Re: Drum brake adjuster
    When I did the drums in my 69 the adjuster (star wheel adjuster?) had thick layer of some sort of grease on the moving parts.
    I think anti seize would do fine.
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,112
    Thanks, Outsider.
