Oil Pressure Warning Light on Intermittently
Results 1 to 13 of 13
Like Tree9Likes
  • 1 Post By csbuckn
  • 1 Post By outsider
  • 1 Post By Mark 78 Coupe
  • 1 Post By jayoldschool
  • 1 Post By AElayyat
  • 1 Post By j2rossit
  • 1 Post By csbuckn
  • 1 Post By cadillac_al
1985-1996 Fleetwood and Brougham Forum Discussion, Oil Pressure Warning Light on Intermittently in Past Cadillac Vehicle Discussion; I have a weird issue with my Oil Pressure warning light. + It only comes on when the transmission is ...
    nebulosity's Avatar
    nebulosity is offline Cadillac Owners Fanatic
    Automobile(s): 1984 Cadillac Coupe DeVille
    Mar 2012
    San Jose, CA
    32
    283
    QuestionOil Pressure Warning Light on Intermittently
    + It only comes on when the transmission is in drive and the car is completely stationary or barely moving
    + When the transmission is in drive and the car is moving, the light goes off right away.
    + When I put the transmission in park, the light goes off right away.
    + The light tends to flicker most of the time and only becomes a solid light after its been flickering for about 30 seconds
    + The light seems to be triggered when I'm turning the steering wheel as I finish pulling into parking spots
    What's strange to me is the fact that the transmission seems to have an effect on the engine oil pressure... or at least it's having an effect on the circuit that's triggering the warning light. I didn't think they were related...... right?
    I looked it up in my shop manual and it says the light comes on when the oil pressure varies within a standard deviation of the acceptable pressure range (I think it was 4 psi or something.. I don't have the manual in front of me.) I checked the oil just after the light had come on, and it looks relatively okay.. it's up against the top mark of the full range, but not beyond it.
    It looks like theres a trouble shooting procedure for this, but before I go through all that, I wanted to find out if anyone has had a similar problem and what their solution was.
    Thanks in advance.
    PS: I went to the DMV this morning, and the stupid person was really picky about reading vin numbers... they need two, and there were a couple numbers on the dashboard plate they couldn't read very well, so they sent me away and told me to have CHP verify the vin numbers. Here's my caddy at the DMV:
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,618
    Change the oil. The oil isn't at the right level or is too thin. That or the sensor is messed up. I only had a quart of oil in my van when the light started flickering and I must have read the dipstick wrong, very embarrassing as a mechanic. Drain and get some decent oil, maybe 10/40. Also, try another dmv, that's what I did when I didn't like the answer from another. The person makes the difference.
    nebulosity likes this.
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,192
    Re: Oil Pressure Warning Light on Intermittently
    If you're sure the oil is good and at the right level could the engine be idling too low? Maybe it's idling low and that's why it doesn't pump enough oil when under load (in drive) or turning the wheel (more load because of power steering pump resistance.)
    Just a thought.
    nebulosity's Avatar
    Mar 2012
    San Jose, CA
    32
    283
    Quote Originally Posted by csbuckn View Post
    I just changed the oil at the end of July... I think it was the Valvoline high mileage 10w30. Despite my engineering background, I'm embarrassed to say I don't understand a thing when it comes to the _w_ viscocity designations. How do I find out what the best weight is for San Jose weather? Hottest in the summer is like 100F, coldest in the summer is like 35F.
    I think I may just go to the Los Gatos DMV instead.
    Quote Originally Posted by outsider View Post
    Just a thought.
    It idles between 700-800 rpm. Should be okay, right?
    Yeah, my power steering makes a little bit of a hum when I'm pulling into a parking space. There's quite a bit of fluid in the reservoir, but I think I'll double check it and top it off when I get home.
    Mark 78 Coupe is offline Cadillac Owners Enthusiast
    Automobile(s): 1978 Coupe De Ville, 1993 Fleetwood
    Sep 2011
    Cleveland/Ft. Myers Beach FL.
    58
    529
    I had a 1980 Fleetwood years ago that did the same thing. I could never figure out what it was (did the oil change, checked level, etc.) I eventually sold it to a local guy who continued to drive it for at least a year longer, and it ran fine. Weird.
    nebulosity's Avatar
    Mar 2012
    San Jose, CA
    32
    283
    Quote Originally Posted by Mark 78 Coupe View Post
    I'll eventually have to figure out somehow. I might need to go through the diagnostic tree for the warning light. It's funny because you'd think I'd be excited about debugging it, but I hate debugging circuits. LOL
    Sep 2011
    58
    529
    It scared me at first because of course I thought the engine was going to implode. I got the car for $100 (back when it was worth at least $2500) from a tow company as an abandoned car. It came with no keys, and of course no guarantees. For the price I figured it was worth the gamble. It ran perfectly, just did the weird warning light thing like yours is doing. By the way, if it matters, I put the wrong year in. It was a 1990, not 1980. I drove it for a month or so before I sold it just to be sure I was not selling someone a time bomb.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,985
    This common to the 307 Olds-equipped cars. On those cars, other members have reported fixing the issue by replacing the oil pump. The pump puts out less pressure as it ages. You could try going to a 5w40 for now.
    nebulosity's Avatar
    Mar 2012
    San Jose, CA
    32
    283
    Quote Originally Posted by jayoldschool View Post
    Yeah, I was thinking it was mostly likely the oil pump too. When I resolve the issue, I'll be sure to post the solution. Thanks, Jay!
    AElayyat's Avatar
    AElayyat is online now Cadillac Owners Connoisseur
    Automobile(s): 85 Fleetwood Brougham, 90 Brougham 5.7, 05 Deville DTS
    Feb 2004
    So. Cali
    35
    1,135
    I'd start by replacing the oil pressure sending unit.
    It's a quick & not pricy fix. Make sure to get a GM unit, I have had issues with aftermarket ones.
    Hopefully it's an easy fix, good luck.
    j2rossit is offline Cadillac Owners Enthusiast
    Automobile(s): 85 FW Brougham, 68 Wildcat 'vert, 92 & 96 Roadmaster Wagons
    Jan 2011
    Southern Ontario
    934
    I'm leaning towards oil pump too. The HT-4100 are known for going through them since they are aluminum, I had to do mine last summer. It seems like the light is coming on when the engine is hitting it's lowest RPM's , which seems mechanical, not electrical.
    The other possibility which is equally as much of a PITA to fix is worn out bearings with too much clearance.
    I'd probably drive it until it gets worse, just keep the rpm's up.
    Jan 2008
    Minneapolis
    5,618
    Maybe take the pressure switch out and see if its gummed up
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    It sounds like the trans is just dragging the idle down too low. The ISC is supposed to take care of that. That's what the relearn process is supposed to address. I'm sure the 700-800 rpm idle speed is in park, right? I'll bet it's down to 500-600 in drive. If you do get to verify the oil pressure it will probably be acceptable anywhere above 700 rpm and only low when the idle is lower. Valvoline high mileage 10w30 should be fine for most engines. That's why I don't think it's a cheap/thin oil issue.
    All in all I would verify that the ISC is working. I have never took the time to watch one operate but I assume you should be able to see it bump up the idle a little when a helper puts it in drive with brake on or when turning on the AC. There is a bazillion ISC threads in the FWD Deville section If you really want to understand it thoroughly.
    I was very surprised to hear that your car passed smog but CONGRATULATIONS! It must run pretty clean, so that is a very good sign that the engine is fairly healthy. Good luck and enjoy that Coupe.
  16. Remove Advertisements
