Alignment Within Specs, Wear Continues
Results 1 to 7 of 7
1985-1996 Fleetwood and Brougham Forum Discussion, Alignment Within Specs, Wear Continues in Past Cadillac Vehicle Discussion; Hello Again, Been a while since I've been here. Let me pick your brains again: '89 FWB has been chewing ...
    caddeville89's Avatar
    caddeville89 is offline Cadillac Owners Fanatic
    Automobile(s): 1990 Cadillac Brougham; 1989 Cadillac Fleetwood
    Mar 2008
    Louisville, KY
    31
    399
    Hello Again,
    '89 FWB has been chewing up the outside of front tires. I had it looked at. They told me to replace idler arm and steering damper. I also replaced front shocks. I took it and had it aligned. They said it was actually to spec, and printed out a sheet demonstrating such. However, six months later, I had to get two new tire for the front because they are wearing on the outside. I also notice before and after that taking a sharp right or left hand turn will cause a rattle in the front which sounds like a socket in a tube, going one way when you take the turn, then going back when you turn back. Please advise.
    Thank in advance for your suggestions.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,899
    Re: Alignment Within Specs, Wear Continues
    Center link? Inner/outer tie rods and sleeves? Upper/lower control arm bushings? Ball joints? Have any of those been replaced? Mileage? Steering damper has nothing to do with alignment, nor do shocks.
    I'd get it inspected somewhere else, and get them to check the alignment.
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    39
    1,150
    Could be the spindle nut is loose or the dust cap that covers it is loose. I had that on mine and sounded like how you're describing it.
    Maybe you'll need the add shims on the A arms to reduce the positive camber it has even though it's within specs as you mention
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Something isn't right with the alignment. Might as well let somebody else take a crack at it.
    Mar 2008
    Louisville, KY
    31
    399
    Yeah thanks guys. Thinking I'll just take it somewhere else. Problem is, you finally get the money to bring it in and they don't do it right, so now I have to spend that money again. PITA.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Some alignment specs are too liberal. I like my Cadillacs with zero or very close to zero camber.
    Crooked mechanics can fudge an alignment my leaning on the car or even print someone else's alignment to pass off as yours.
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    To rule out the possibility that your mechanic is lying to you, most Corporate owned shops (Goodyear, Firestone, Monro Muffler) offer free alignment checks. Even if you don't trust them to service your car, a shop like that will have up-to-date alignment equipment/software, and would provide you with accurate alignment measurements.
    I wouldn't trust a company owned garage to do an good job inspecting the front end components. You should look in your area to see if there are any garages that only deal with chassis and suspensions; look for places that do front end repair for auto collision shops, or work on commercial vehicles. A shop like that would be able to do a better job at inspecting your front end, and finding the cause of your tire issues, but they would probably charge for an alignment check.
  10. Remove Advertisements
