Have a question about cruise - 91 Brougham
Results 1 to 6 of 6
1985-1996 Fleetwood and Brougham Forum Discussion, Have a question about cruise - 91 Brougham in Past Cadillac Vehicle Discussion; So I have a 91 Brougham and the cruise doesn't work. I've asked around to friends, club members and others ...
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,930
    So I have a 91 Brougham and the cruise doesn't work. I've asked around to friends, club members and others but no one really knows.
    When I turn on the switch on the dash the amber light comes on but when I push the SET button, nothing happens. No green light, no cruise.
    So before I go digging, does anyone know what may cause that symptom? Is it the set switch in the turn signal wand, fuse, dash switch? Something else?
    Ownership:
    91 Brougham d'Elegance 350
    95 Fleetwood Brougham
    01 Custom Deville DTS
    2011 CTS4 Luxury
    Memberships:
    National and regional Cadillac & LaSalle Club
    Proud Volunteer - Northstar Tuning Project
    Guinness World Records - Largest Cadillac Parade
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,492
    Re: Have a question about cruise - 91 Brougham
    I don't know why cruise would have it's own fuse but maybe it does? I would start by checking the set switch and if it's good check the cruise control unit under the hood to see if it's getting power and getting the set signal when the button is pressed.
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Make sure the vacuum lines to the Cruise Control Servo are connected, and don't have any leaks.
    The Cruise Control Module receives a signal from the brake switch, and if the wire coming from the switch is loose or broken, the module will not allow the Cruise Control to engage. You should also pull off the connector to the CC module, and check for any loose pins or corrosion, which would cause the system to malfunction.
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 118,*** miles
    Dec 2005
    MA
    58
    2,129
    I think cruise will not engage if there are any ABS codes set. A bad wheel speed sensor could do that.
    mjs182004's Avatar
    mjs182004 is offline Cadillac Owners Enthusiast
    Automobile(s): 91Broughamd'Elegance,06STS-V,76FWBd'Elegance,98SevilleSTS
    Dec 2008
    Eastlake, Ohio
    30
    769
    I know the cruise will work with the ABS light on, I've been doing it for 6 years now. lol
    sven914's Avatar
    Dec 2008
    4,256
    The ABS light doesn't mean a code has been set. It means the ABS system is turned off, so if the unit has been unplugged, the light will turn on, but the computer might not register a trouble code.
  9. Remove Advertisements
