"Not Charging" light intermittant
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By jayoldschool
1985-1996 Fleetwood and Brougham Forum Discussion, "Not Charging" light intermittant in Past Cadillac Vehicle Discussion; I have a 1991 Broughm. The "Not Charging" light comes on intermittantly. If it were on steady, I could have ...
    Jim_S is offline Cadillac Owners Member
    Automobile(s): '91 Brougham, '96 de Ville
    Aug 2013
    3
    I have a 1991 Broughm. The "Not Charging" light comes on intermittantly. If it were on steady, I could have the alternator tested.
    But with intermittant, it is only on when I am not at the mechanic's shop. Any suggestions what could be causing this?
    Jim S
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: "Not Charging" light intermittant
    Your battery is on it's way out. If you can access the cells, check the level of your electrolyte.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,614
    I'm thinking the alt is going out.
    Aug 2013
    3
    The battery is 12.26V. This is a little less than 12.6,
    possibly because the voltmeter is inaccurate or possibly because
    the alternator has not been steady. The battery is 4 years old.
    Originally rated at 800 CCA. Now down to 580 CCA. The shop manual
    says that "Not Charging" comes from the altenator. It does not
    mention battery.
    csbuckn,
    Of course, the altenator is the first thing to consider. I suppose
    my real question is: "Is it common for an altenator to degrade
    gradually and fail intermittantly?" If so, I condemn the altenator.
    But if altenators always either work, or not work, then the
    light should stay on or off. If this is the case, I should
    trust that the altenator is working and look for a loose
    connection somewhere between the altenator and the dash
    light. I do not want to replace the altenator unless I am
    sure that the altenator is the problem.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,957
    There's another possibility to consider. A failing belt tensioner, causing the belt to slip on the alternator pulley, causing poor charging, causing low battery output.
    nebulosity likes this.
    Aug 2013
    3
    Quote Originally Posted by jayoldschool View Post
    Jayoldschool,
    Thank you for this tip. I had not considered it. It is definitely something I will have a look at. However, I do not hear a squeel that I usually associate with a slipping belt.
    Jim S.
    Sep 2006
    Ontario, Canada
    44
    7,957
    Serp belts don't squeal.
    j2rossit is offline Cadillac Owners Enthusiast
    Automobile(s): 85 FW Brougham, 68 Wildcat 'vert, 92 & 96 Roadmaster Wagons
    Jan 2011
    Southern Ontario
    934
    I was thinking belt too, but I'm more familiar with the v-belts. last year I had a loos belt and I'd get the occasional charge light flicker with no belt squeal. I would check that the belt hasn't stretched past the range of travel for the tensioner.
    But a battery sitting at 12.2 isn't great. I'd throw a charger on and check that it's capable of holding a good charge.
    Mar 2006
    1,493
    Your battery is four years old and how many times has it been discharged? A rule of thumb on a discharged battery 3 times and out.
    Neil Clarke's Avatar
    Neil Clarke is offline Cadillac Owners Member
    Automobile(s): 76 Sedan Deville
    Dec 2009
    Perth Western Australia
    48
    89
    My 76 was doing something similar
    Turns out the alt was still charging fine but the diode in the alt that worked the light was faulty
    Mar 2006
    1,493
    A diode on the way out is usually indicated by a constant flickering of the indicator light.
  14. Remove Advertisements
