olds 307 V-belt tensioning?
Results 1 to 3 of 3
1985-1996 Fleetwood and Brougham Forum Discussion, olds 307 V-belt tensioning? in Past Cadillac Vehicle Discussion; Hello! Are there anyone here that's familiar with tensioning the belts on the olds 307? The belt for my AC ...
    Jeppi94's Avatar
    Jeppi94 is offline Cadillac Owners Fanatic
    Automobile(s): 1989 Cadllac Brougham
    Jul 2013
    Gothenburg, Sweden
    22
    158
    Hello!
    Are there anyone here that's familiar with tensioning the belts on the olds 307? The belt for my AC Compressor is squealing when it's under pressure and the belt for the device beside...which i believe is a vacuum pump, it's belt is soo lose that it wobbles while spinning. Anyhow, the only tensioning bolt I've seen is the one for the generator belt, are there more or is that one for the entire system?
    meteor is offline Cadillac Owners Member
    Automobile(s): 1987 brougham
    Jul 2013
    edison nj
    66
    4
    Re: olds 307 V-belt tensioning?
    Just replaced all the belts on my "new" 87 Brougham. It is not an easy job and the pulleys barely move, I have never seen brackets like these. I would install new belts so you know they are not stretched. Loosen all the brackets and exercise them to get easier movement. Also all the belts are the cog type. They don't slip but they do bounce. I like regular belts but may be harder to get. the AC and air pump belts are the hardest.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    When I did the alt belt on my 307, I ended up using a large screwdriver (as a prybar) to swing the alt up into place so the belt wasn't slipping.
