Help to ID a vacuum line on 68 Deville
Results 1 to 7 of 7
1985-1996 Fleetwood and Brougham Forum Discussion, Help to ID a vacuum line on 68 Deville in Past Cadillac Vehicle Discussion; HI all. I have been troubleshooting the AC this week. Went from nothing to now have air and heat! There ...
    jukelemon's Avatar
    jukelemon is offline Cadillac Owners Member
    Automobile(s): 1968 Deville Convertible
    Jul 2013
    Louisville, KY
    60
    HI all.
    There is a line that is coming out of the firewall, Driver's side along with 5-6 others that is not connected to anything (engine side).
    Before you ask...I do have the manual and the 68 vacuum diagram
    The first issue is that I cannot tell if it is "tan" or "yellow".
    Second is that I cannot see where there is any open port to where it should go.
    Third, I am assuming this is going to the AC control but no 100% positive.
    Any assistance would be great.
    Thanks
    Jason
    I found it..
    Idle Up Valve.
    Mine was not hooked up
    Dirtywaterdiver's Avatar
    Dirtywaterdiver is offline Cadillac Owners Fanatic
    Automobile(s): 1968 Convertible
    Jul 2010
    Boston MASS
    268
    Re: Help to ID a vacuum line on 68 Deville
    I am having the same problem. But I am also color blind so BONUS!
    Garys's Avatar
    Garys is offline Cadillac Owners Fanatic
    Automobile(s): 1968 CDV / 1970 FWB /1979 FWB / 1995 Eldo
    Aug 2007
    San Diego
    228
    My 68 has all of its vacuum hoses in tact. I will be pulling out of storage soon, and will let you know what those hoses are for, unless you find out sooner.
    Jul 2010
    Boston MASS
    268
    Thanks. I have 4 lines hanging down with screws blocking the ends. God knows where they go.
    804fleetbro is offline Cadillac Owners Member
    Automobile(s): 1980 Fleetwood Broham
    May 2013
    29
    34
    what size are the vacuum line hoses? I need to replace mines
    jukelemon's Avatar
    Jul 2013
    Louisville, KY
    60
    I believe they are 1/4" hose lines in that area. Others are bigger.
    I found the issue. I had another more detailed Vacuum layout that showed what actually came through the cowl.
    On a down side, the idiots who replaced the carb prior to me getting the car bought one without an idle up valve i.e. for a non AC caddy.
    So, that function is gone.
    Oh well. Air works well now and thankfully. A little warm and humid here these days.
    Jeff R's Avatar
    Jeff R is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Coupe De Ville//Cessna 172
    May 2013
    St. Louis
    47
    544
    The ony you're holding may go to the water shut-off valve for the heater core. I have a 70 and the one that is that color goes to the heater valve.
  10. Remove Advertisements
