Results 1 to 12 of 12
Thread: '78 Coupe de'Ville Headlights Won't Dim
    Mercedesman is offline Cadillac Owners Member
    Automobile(s): 1978 Coupe de'Ville
    Aug 2013
    5
    Hello, New to the forum. Please forgive my ignorance. I have searched this issue here but I am still stumped on the issue. The lights operate but they will not dim with the floor switch or via the automatic headlight dimmer option. I suspected the floor switch so i removed it from the car. Should the headlights still work if the floor switch is removed? I figured the lights would go out without the floor switch connected. I am also finding out that the floor switch is obsolete and the only one I have been able to find is $75!!! I would appreciate any sound advice that could be given. The car is not a daily driver but I really would like to be able to drive it at night and not blind oncoming traffic.
    1978 Coupe de'Ville 61,250 miles! I love this car!!!
    Aug 2013
    5
    Re: '78 Coupe de'Ville Headlights Won't Dim
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,981
    The switches that I find are all "without Guidematic" automatic dimming. So, my guess is that there is a different dimmer for your auto dimming setup.
    First up, your FSM will likely have a trouble-shooting tree to figure out exactly what part is the problem. If you don't have an FSM, I can think of three options:
    1. Spend the big money, and change the switch (and hope that's the problem).
    2. Rewire the system, use the cheap switch, and bypass the Guidematic.
    3. Unplug the high beams.
  5. #4
    Aug 2013
    5
    I just did option #1 so while I wait on option #1 to arrive how do I go about disabling the high beams, option #3? If this were a Mercedes w123 chasis then I would know what to do. Oh the joy of the learning curve! LOL!
    Unfortunately at the moment I do not own a FSM.
  6. #5
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    40
    1,150
    Quote Originally Posted by Mercedesman View Post
    If you remove the floor mounted dimmer switch all front headlights would be inoperative. I can check my service manual to see what it says related this your issue, but that won't be until tomorrow morning. I'm at work right now..more than likely, it's the dimmer switch that is the culprit. Or it can be the guidematic control, which has sensors up front behind the grille. But definitely tomorrow I'll post..
  7. #6
    Aug 2013
    5
    Thanks!!!!!!!!! I have the dimmer switch completely removed from the car and the headlights STILL WORK but of course they are on high beam. I thought that when I removed the dimmer switch that it would cause the lights to go out BUT they did not. My car must be special. Haha!
  8. #7
    1980coupe's Avatar
    Jan 2009
    El Paso, TX
    40
    1,150
    That or someone in the past rigged up a direct wiring. I don't see how they'll still work without it. Like I said, first thing in the morning I'll see what it says and I'll scan the images...
  9. #8
    Sep 2006
    Ontario, Canada
    44
    7,981
    Remove the high beams, unplug them. Just for now.
  10. #9
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    I'd check the circus diagram to see of your auto gizmo is in parallel with the dimwit switch. Could be a stuck relay inside.
    Ex 124, 126, current W-140 X2 owner : ) That's so you know I'm a confirmed nutcase.
  11. #10
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    45
    1,845
    "circus diagram" I like that. Very appropriate
  12. #11
    Sep 2006
    Ontario, Canada
    44
    7,981
    Also, pick up an FSM on ebay. It's a must have for any classic car owner. It's what the dealership tech used to fix your car, you should use it, too.
  13. #12
    Aug 2013
    5
    Fixed it!!! At some point someone had been rooting around at the fuse panel and managed to plug the
    system up wrong. Plugged everything up correctly and now the headlights dim properly. Guidematic isn't
    working but at least the floor dimmer works!
  • You may not post replies
