A few questions from the new fleetwood owner...
Results 1 to 13 of 13
1985-1996 Fleetwood and Brougham Forum Discussion, A few questions from the new fleetwood owner... in Past Cadillac Vehicle Discussion; Traveled to st louis last week for a 95 fleet . Tow package car, 175k . Got a good deal ...
    Reverend Hearse's Avatar
    Reverend Hearse is offline Cadillac Owners Member
    Automobile(s): 1984 Collins hearse, 1979 Coupe , 1984 Seville,1990 fleet'
    Oct 2010
    32
    86
    Traveled to st louis last week for a 95 fleet . Tow package car, 175k . Got a good deal and brought it home, it cleaned up quite nicely . I have a few questions..
    The previous owner said the car needs a power steering pressure switch. Would that cause the car to have stumble issues when doing low idle turns ?
    When i take off theres a definite hesitation and i must push more into the pedal past it... Wheres a good place to start a diagnosis?
    Is the tow package 3.73 rear a limited slip , requiring a special fluid?
    Oct 2010
    32
    86
    Re: A few questions from the new fleetwood owner...
    alrighty.... or not ...... off to find factory manuals....
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,955
    Power steering pressure switch may cause that low speed stumble on turns. Unplug it to find out.
    Hesitation is usually ignition. Start with coil wire, then plugs, then ICM, then wires. Then start to think opti.
    Tow pack is 3.23, non posi. No additive. No 94-96 Fleetwoods got posi.
    Oct 2010
    32
    86
    what will unplugging it do? send it to full assist?
    Gman1023 is offline Cadillac Owners Fanatic
    Automobile(s): 2013 CTS-V Wagon, 1996 Fleetwood Brougham
    Feb 2013
    Pittsburgh, PA suburbs
    27
    202
    Wrong again. 94-96 tow pack has 3.42.
    Feb 2003
    california
    69
    6,680
    The pressure switch raises the curb idle slightly when turning sharp to park. Its probably not doing that. Unplug it and find out!
    Oct 2010
    32
    86
    Hell I can't even see the switch ..... It is back to stumbling again.... Kind of irritating . It does in traffic the other day . Started right back up . I can't find anyone with a OBD 1 scanner . The check engine light comes and goes ...
    Sep 2006
    Ontario, Canada
    44
    7,955
    You have an OBD1 scanner, it's built into your car. See the FAQ sticky for how to access the data through your HVAC head. I don't have a 94-96 anymore, but I seem to recall that the steering assist connector just plugs into the top of the steering box. Driver's side frame rail, under the air intake tubing...
    Oct 2010
    32
    86
    I got code 13 oxygen sensor circuit fault . When doing the diag , I get 111 instead of a actual voltage , which I assume means there's ashorT , possibly a bad o2 sensor??
    Oct 2010
    32
    86
    I need a idea... I notice tonight I have no brake or turn lights . All other lights function fine. A fuse diagram would be most helpful ....
    Sep 2006
    Ontario, Canada
    44
    7,955
    Fuse diagram is on the sticker on the back of the fuse panel cover. Driver's side door jam, end of the dash. There are more fuses in the AUX fuse fox under the hood (with their own diagram on the lid bottom).
    Feb 2003
    california
    69
    6,680
    The brake and turn lights being inop should be a new thread.
    Oct 2010
    32
    86
    Quote Originally Posted by jayoldschool View Post
    theres no lid , however after pulling all of them , i found the one for the lights , when replaced, it blows again... off to find out why...
    carnut, i grouped it here with the general issues im having with this leftover junk car , didnt see a reason for a new thread, sorry...
  16. Remove Advertisements
