Having trouble removing rear wheel seal/bearing from rear shaft. 12 bolt differential
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Cadi dog
1985-1996 Fleetwood and Brougham Forum Discussion, Having trouble removing rear wheel seal/bearing from rear shaft. 12 bolt differential in Past Cadillac Vehicle Discussion; Having trouble changing leaky wheel seal.. 1974 Cadi.. 472 c.i. any good links???.. 12 bolt This rear differential is NOT ...
    Cadi dog's Avatar
    Cadi dog is offline Cadillac Owners Member
    Automobile(s): 1974 Cadillac Coupe DeVille
    Jul 2013
    Having trouble changing leaky wheel seal.. 1974 Cadi.. 472 c.i. any good links???.. 12 bolt This rear differential is NOT ' C ' clip type. It is bolted on to differential, 4 bolts hold the shaft in place. Help cadi dudes. when i pulled out shaft the bearing and seal comes with it . there is a circular metal holding bearing and seal in place.. Any help how to remove and replace?
    talismandave likes this.
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    58
    7,894
    Re: Having trouble removing rear wheel seal/bearing from rear shaft. 12 bolt differen
    Sweet car dog!
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    You can remove these by: 1 - heating the ring - it is a press fit and locks the bearing to the shaft. or: 2 - cold Use a chisel and hammer and place it between the retaining ring and the bearing. Strike it around the circumference of the ring and bearing. It will start to move, slowly, but will eventually come off. Then use the same tools to remove the bearing from the shaft. OR 3. take the assembly to an auto machine shop that has a press to remove the retainer and bearing and replace.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    If you choose not to send it out please wear eye protection while using a chisel.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,983
    Use a press. Do it the right way.
  8. Remove Advertisements
