Flushin the engine and radiator on a 1976 500ci
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By lacville78
  • 1 Post By blueboy
1985-1996 Fleetwood and Brougham Forum Discussion, Flushin the engine and radiator on a 1976 500ci in Past Cadillac Vehicle Discussion; Anyone got tips for flushing the coolant out and cleaning the pathways on a 1976 500ci?...
    blueboy is offline Cadillac Owners Fanatic
    Apr 2005
    nashville, tn
    100
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    Re: Flushin the engine and radiator on a 1976 500ci
    For flushing, I use the bolt on the bottom of the radiator for draining the radiator. this will get rid of most of the old coolant. I guess you could pull the top hose, and run fresh water through it and have it dump out through the lower hose of the radiator (don't quote me on this, but it should work)
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,198
    I've heard running some CLR through it helps
    Apr 2005
    nashville, tn
    100
    Clr?
    I guess what I'm really asking is how to get the water ways cleaned out...this engine has been sitting for some time and there is probably quite a bit of build up in the system. Looking at the radiator with the cap off I can see quite a bit of build up. S'pose I could pull the rad and have it cleaned. Just wondered if anyone had experience flushing the cooling system?
    nebulosity's Avatar
    nebulosity is offline Cadillac Owners Fanatic
    Automobile(s): 1984 Cadillac Coupe DeVille
    Mar 2012
    San Jose, CA
    32
    283
    Quote Originally Posted by blueboy
    Clr?
    CLR: http://www.thecarycompany.com/contai...FRDZQgodAB4A7A
    Obviously you dont need industrial strength stuff, but now you know what it is. Ie never heard of it bekng used in an engine block, but I imagine it would do a really good job cleaningg it out. I was thinking of using it on my radiator. Gotta make sure you rinse well.
    lacville78 is offline Cadillac Owners Fanatic
    Automobile(s): None at the moment
    Feb 2011
    30
    374
    They sell system flush at the parts stores, just pull the thermostat and follow the directions on the bottle. I also use this tool that hooks up to compressed air and a water hose to help flush it.
    I forget the name of the tool, but I know it says Sears on it, I think it is from the 60s or so, I wonder if they still make them. Anyhow they really help.
    nebulosity likes this.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,620
    You could flush the radiator and engine separately. Take both radiator hoses off, flush the engine from the thermostat inlet, flush the radiator from the upper inlet. Put the lower radiator hose back on and fill the engine from the thermostat inlet.
    Apr 2005
    nashville, tn
    100
    OK, I'm getting ready to flush everything this weekend. Also change out the oil and filter for both transmission and engine...new food for the beast! Thanks guys. Gosh really appreciate this forum and the help it gives us :-)
    Apr 2005
    nashville, tn
    100
    Hit a hitch...bad electrics couldn't get started. New battery may solve the issue. So, next weekend...til then......
    Dec 2010
    St. Louis, MO
    6,397
    Change the radiator hoses while you're at it. They probably need to be changed and it is cheap insurance from a failure on the road.
  13. Remove Advertisements
