trans ?
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
1985-1996 Fleetwood and Brougham Forum Discussion, trans ? in Past Cadillac Vehicle Discussion; Hey guys, me again LOL.. well, I fix one issue, then another pops up. Ok, this one is big. I ...
    slayu2day's Avatar
    slayu2day is offline Cadillac Owners Member
    Automobile(s): 1994 fleetwood
    Oct 2011
    Gilbert, Arizona
    49
    51
    Exclamationtrans ?
    Hey guys, me again LOL.. well, I fix one issue, then another pops up. Ok, this one is big. I was driving home and a block from home, trans started to slip. Within a half a mile, it was completly gone. I just got home and in my parking spot. I lost all forward gears and reverse. I have never had a trans do that. Its not low on fluid. Is there a fuse, or a soleniod or a vacume module or something that would do this ? I hope I don't need a whole trans.
    silverfox103's Avatar
    silverfox103 is offline Cadillac Owners Fanatic
    Automobile(s): 96 Fleetwood & 07 CTS, 94 Roadmaster Wgn & 94 Caprice Wgn
    Aug 2012
    Littleton, NH & St. Simons, GA
    68
    414
    Re: trans ?
    When the transmission goes on these things, Caddies, Buicks and Chevies with the same tranny, it usually means a replacement or a rebuild. You don't know how lucky you are that you made it home. My Caprice wagon with that same tranny, let go 700 miles from home. I had to have it flat bedded home. I was lucky I had stockpiled a tranny that had 80K on it, that I paid $140; it still cost $500 to R & R it, but I was happy.
    Tom
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,614
    Sounds like the pump maybe. How does the fluid smell?
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    Re: trans ?
    Unfortunately that's going to need to come out and probably rebuilt. Once they start slipping, the damage happens fast.
    If you find a used one, make sure it's from the same model year. Trust me, you don't want to go down the path of interchanging different year transmissions.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Re: trans ?
    A blown fuse will not cause no movement.
    If the pump broke, the fluid will be too high on the stick.
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Re: trans ?
    Here's a link to help with the diagnosis:
    http://www.s10forum.com/forum/f13/4l...utions-297698/
    See #21.
    Feb 2012
    NYC
    49
    1,948
    Re: trans ?
    The strange part is the slipping.
    Usually when the pump breaks, there is no slip. It just stops moving.
    First, check to see if you have the swedged rubber damper drive shaft.
    I don't remember which cars had these, but it may feel like a slip before it goes.
    slayu2day's Avatar
    Oct 2011
    Gilbert, Arizona
    49
    51
    Re: trans ?
    what will have to be done to put in a 7004r trans in my fleetwood ?
    Feb 2012
    NYC
    49
    1,948
    Re: trans ?
    Why? It's mechanically the same. Just no solenoids. No advantage.
    You would need a cable. Lockup would not work properly. MIL would be on.
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Re: trans ?
    You need to find a '94 trans out of a Caprice, Roadmaster, F-body or Fleetwood. I found Craigslist was a good source.
    I happened to have a '96 trans laying around when my '94 trans quit. I was able to make it work, but the work involved is not for the faint of heart.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,940
    Re: trans ?
    If he gets one from an F body, he will need to swap his tailshaft on to the new trans.
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Re: trans ?
    Quote Originally Posted by jayoldschool View Post
    Yes tailshaft housing - good point.
    slayu2day's Avatar
    Oct 2011
    Gilbert, Arizona
    49
    51
    Re: trans ?
    I'm sorry, I meant 700r4. And I was told just need to change some electrical plug out to the right kind.
    The reason I'm asking about this kind is I can get one from a buddy for half the price.
  16. #14
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Re: trans ?
    Quote Originally Posted by slayu2day View Post
    Like mentioned above, it would be more trouble than it's worth. The 4L60E is the next iteration of the 7004R and is electronic (hence the E). I don't know what sort of problems you would endure from the PCM not seeing the transmission anymore. Maybe no more than a MIL light - dunno. The biggest challenge would be rigging up a bracket for the TV cable and getting it adjusted properly. They were very finicky and you have to have the right geometry on the throttle bracket in order for it to work right. I HATED that on my GN (yes, it was a 2004R, but same principle).
  17. #15
    slayu2day's Avatar
    Oct 2011
    Gilbert, Arizona
    49
    51
    Re: trans ?
    Well I found the original trans. my car came with. I put it in, works ok. But, I keep popping the emmisions fuse under the hood. Its a 10 fuse...is my o2 sensors shorting or is it one of the plugs that go to trans ?
  18. Remove Advertisements
