Paint job on 76 cdv - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
1985-1996 Fleetwood and Brougham Forum Discussion, Paint job on 76 cdv in Past Cadillac Vehicle Discussion; I mentioned earlier in your other post that all of this is really up to you and how much time ...
  1. #16
    Mark 78 Coupe is offline Cadillac Owners Enthusiast
    Automobile(s): 1978 Coupe De Ville, 1993 Fleetwood
    Sep 2011
    Cleveland/Ft. Myers Beach FL.
    58
    528
    Re: 76 CDV Rear Window Meets Trunk Replacement
    I mentioned earlier in your other post that all of this is really up to you and how much time and money you want to invest. Could you grind most of the rust, and fill it with Tiger Hair, bondo, or whatever? Yes, of course you can. Will it last? Maybe, maybe not. If the car is garaged, and out of bad weather, the cheap fix will last longer than if it is exposed to the elements. But, taking out the rear glass and welding in new steel (after sandblasting the old stuff to get all the residue of rust out) is the only (almost) sure fire way to stop the rust from returning. Why don't you give us an approximate dollar amount that you want to spend in total on body and paint? That way maybe I can help with some ideas from prior projects I've done.
  2. #17
    blueboy is offline Cadillac Owners Fanatic
    Apr 2005
    nashville, tn
    100
    Thanks guys. I understand that the 'proper' way to do this is a the welding of a fresh piece of metal in place below the window, after a sand blast to make sure there is no rust still in there. My dilemma is whether it is worth spending what could be a considerable amount on this as opposed to just patch it with GF/Bondo.
    1. Do I want to spend a considerable amount of money on bodywork in bringing Blueboy back to a reasonable new lease of life?
    2. Is it really worth spending a considerable amount of money when I could buy another fairly good, rustless example for what I might spend on getting Blueboy back to life ?
    3. Mechanically she's fairly good, engine, brakes, trans, suspension all in reasonably good condition.
    4. There are other rust spots.....the trunk lid (have located a new lid from AZ...in primer,no rust) and under the dash for a start but probably easier to deal with. The trunk floor is good and after my POR 15 arrives, will be solved.
    Do I want to keep the car for any length of time?
    I realise these are all questions that I have to answer myself and I want to do things right by Blueboy but lets face it this is a car!
    My plan was to spend some $2/3 grand at most including a paint job and vinyl top. Prepping I can do but the paint job and vinyl top will have to be done professionally.
    At present I have no garage to cosset Blueboy..just a meager car port.
    I will appreciate your comments chaps. BTW thanks for the tips and the advice on this forum.
    IMHO these cars are magnificent beasts of the road and I love them dearly and I have had some exotic cars both European and American in my time.
    Rock on
  3. #18
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,612
    Are those studs for mounting the vinyl top or are they screws to hold the decklid in place? You're gonna have to cut it out and weld in a thin sheet. They have stud rivets you will be able to use to make the mounting studs again. Doesnt look like a terrible job.
  5. #19
    Sep 2011
    58
    528
    From what I can see, the rust on your car is really not that bad. The fender skirt era cars rusted very badly in that area, and yours looks very solid, no doubt due to its western heritage. Doing a proper fix on the rust by the rear window would really not be that big of a repair. If you plan on making her your "forever" car, and still want to stick to some kind of budget, here is my idea. Cut out and weld new metal by the back window. Then, get a moderately priced budget paint job from a place like Maaco. If you do proper prep work, Maaco paint jobs really look fine. They paint cars all day long, so they put it on smoothly. They also use PPG products (at least up north) which are excellent quality. Enjoy the car for a few years with that paint job, and in the mean time sort out any other issues (front seat, mechanical gremlins, etc). Once all other issues are addressed, then pop for the big dollar paint job, if you choose. And big dollar can start at $2000 and go way up from there. But, like I said, a properly done Maaco job is really nothing to be ashamed of. Painting is the easy part-all the work and time is in the prep.
  6. #20
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,152
    The right way to do it is to weld in new metal however if you are on a tight budget (welding can get expensive...) You could get away with fiberglassing it in. It's not the "right" thing to do but properly treating the metal with some rust inhibitor and cutting out the bad parts before fiberglassing it in will result in a good finish that will last.
    As has been said, it's up to you how much you want to pay and what kind of quality you're looking for. I see no shame in fiber glass and bondo. I've used a ton on my 69 and although it's not perfect it's a lot better than it was and in the end do you want a show car or a car you can go out on the road with and enjoy?
  7. #21
    Sep 2011
    58
    528
    From what I can see in the pictures you have provided it looks like the only real rust is around the back window and the deck lid. If you budget some money to do the rear window repair properly (sand blast, new steel, etc) you will end up with a very solid car. And, in a few years time if you want a different car, having done this one properly will enable you to sell it at a very good price. You have an advantage in that it was always a western/southern car, and it is a beautiful color combination. My vote is to do the rust repair properly. Like I said earlier, having it really solid in the fender skirt area is a huge selling point if you choose to sell in the future. Make your investment now and you will be re paid handsomely later.
  8. #22
    Apr 2005
    nashville, tn
    100
    Thanks guys. Yes the rest of the car is in pretty good shape, fender skirts included. I'm going to make some enquiries as to the cost of sand blasting and replacing the back window window deck lid. The result will determine my course of action. The vinyl top will come off this weekend which will certainly reveal anymore problems although I am confident that its just the back window deck lid. Then new boots, insurance, tag and a short run or two will help promote enthusiasm. I found that replacement seat covers in white leather can be had for $1100. Don't know yet what the labour cost of having them fitted will be. I'm pulling the dash apart right now as the main support bar and other metal parts have surface rust...gosh its complicated ! Thanks so much for all your advice and enthusiasm.
  9. #23
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,902
    Time to prioritize. Why worry about surface rust on a dash support bar? You've got bigger things to deal with. Last thing you want is a car with the top torn off, dash apart, sitting, rotting...
  10. #24
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    Mine had/has that too. I agree with Jay, on mine I hit it with WD40 and got on with my life. I have never had a car rust out from the dash support out.
  11. #25
    Neil Clarke's Avatar
    Neil Clarke is offline Cadillac Owners Member
    Automobile(s): 76 Sedan Deville
    Dec 2009
    Perth Western Australia
    48
    89
    Fix it properly
    I'd hate to buy a car full of half arsed repairs
    And I'm sure you would too
    Do yourself and the new owners a service and either fix it properly or sell out now to someone who will
    Classics should be protected
    Its not a plastic car... don 't fix it with it.
    I'm sure a sheet metal worker would be able to fab that part up easily (looking at my 76 sedan)
    Seems however here in Australia we weld repair and fix things you guys bog up
  12. #26
    Apr 2005
    nashville, tn
    100
    Got a quote from local company on having the padded vinyl top fitted ...$450 all in! I'm excited that seems to be a very good deal. Here's before/after pics of their gallery:
    http://www.flickr.com/photos/62382565@N03/9573976685/
    http://www.flickr.com/photos/62382565@N03/9576771802/
    I like the crest and "V" on the quarter panel...
    POR 15 has arrived ...tomorrow sees the trunk floor painted.
    Getting there :-)
  13. #27
    Sep 2009
    33
    4,152
    Hey make sure you don't get any por 15 on your skin...it will not come off for weeks. I had black hands for weeks when I did mine because i wasn't smart enough to wear gloves lol
  14. #28
    Apr 2005
    nashville, tn
    100
    Re: Paint job on 76 cdv
    Thanks Man. I'm getting quotes on replacing that rear deck. Also on hiring a sand blaster......this is all new to me.
    I have a quote on the padded vinyl top replacement..$450 for the lot with my prep. Not bad :-)
    Here's an example of their work.
    I'm about to paint the trunk floor with POR 15.
    She's moving!
  15. Remove Advertisements
