Pics of the 77 CDV after paint
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Like Tree4Likes
1985-1996 Fleetwood and Brougham Forum Discussion, Pics of the 77 CDV after paint in Past Cadillac Vehicle Discussion; Some pics as promised, I will try to get some more at a more scenic location sometime later, also the ...
    lacville78 is offline Cadillac Owners Fanatic
    Automobile(s): None at the moment
    Feb 2011
    30
    374
    Some pics as promised, I will try to get some more at a more scenic location sometime later, also the front fender spear on the PS side was off due to it being loose after washing it. I didn't want to lose it, so I took it off and will re attach it more securely.
    The front end is back together with the parts I got from CadillacKevin.
    Thanks everyone!
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    Re: Pics of the 77 CDV after paint
    Wow! That came out gorgeous!
    nebulosity's Avatar
    nebulosity is offline Cadillac Owners Fanatic
    Automobile(s): 1984 Cadillac Coupe DeVille
    Mar 2012
    San Jose, CA
    32
    283
    Beautiful!!
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    39
    1,150
    Nice work.
    Why are there holes in the hubcap and what happen to the front passenger side bumper?
    Mar 2012
    Madison WI
    57
    7,893
    Old style of locks for wire caps.
    1980coupe's Avatar
    Jan 2009
    El Paso, TX
    39
    1,150
    I have locks on mine and it's not like these on his Caddy. Mine are on either side on the outer edges of the hubcap and lock into the slots of the rim.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Nice!
    1980coupe's Avatar
    Jan 2009
    El Paso, TX
    39
    1,150
    Oh and mine are factory
    Corey468's Avatar
    Corey468 is offline Cadillac Owners Fanatic
    Automobile(s): 1976, 1994 Cadillac Fleetwoods, 1996 Lincoln Town Car
    Sep 2012
    Walnut, CA
    21
    167
    Very nice! She looks gorgeous.
    Feb 2005
    Southern NJ
    54
    2,096
    My '77CDV came with factory locking hubcaps. They used J bolts which fit into the slots in the wheel rims near where you would pound the wheel weights on. The bolts went through small holes in the hubcaps and there were little specialty nuts with keyed heads. You couldn't see the locks at 5 paces and the hubcap would not fly off.
    Later models had captive J studs built into the hubcaps in the same spots. The studs got turned 90 degrees after popping the hubcaps on.
    Still later the hubcaps from 1986 era turned into gutless wonders held on in the center. Very light and a similar but not so cool spoke wheel look. That's what I have. I do miss the look of the older caps a little.
    Late hubcaps combined with factory 1981 alloy wheels (which were painted black from then factory) save about 11 lbs per wheel over a 1977 setup. I'm nuts about keeping unsprung weight low for the improved ride. A giant weight savings over the W.R. Grace and Co. spoked rims which came with my 1980 FLeetwood. A guy down South was happy to give me $1000.00 plus shipping back when ebay was nuts.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    My 86 hubcaps are old style with the center lock bolt. I swear those things weigh 10lbs a piece. If those flew off, you'd do serious damage. And alloy rims? You mean wheels that looked like the steel wheels but were aluminum? Interesting. I guess those were a california thing (like the aluminum hoods)?
    blueboy is offline Cadillac Owners Fanatic
    Apr 2005
    nashville, tn
    100
    Is that a new vinyl top? Be interested in how you protected it from paint?
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by blueboy
    I would think you just tape it off.
  16. #14
    Feb 2005
    Southern NJ
    54
    2,096
    Quote Originally Posted by cadillac kevin View Post
    The alloy rims came on certain 8/6/4 cars. Not sure where else. They look like regular steel at first. I've had mine since the mid 80's. My '80 Fleetwood 2 door has the aluminum hood and it has always been a NJ car. That is a crazy year for this model so who knows what they were up to.
  17. #15
    Feb 2011
    30
    374
    Quote Originally Posted by 1980coupe View Post
    Nice work.
    When I got the car it was missing the hubcaps, these are some beat up ones I got from the junkman for $10, the holes are probally from someone drilling out a lock or something.
    And the bumper was like that when I got it, maybe wreck damage.
    Quote Originally Posted by blueboy View Post
    Not new, it was masked and taped off.
    Quote Originally Posted by The Ape Man View Post
    The asbestos people made rims?
  18. Remove Advertisements
