Pics of the 77 CDV after paint - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 32
Like Tree4Likes
1985-1996 Fleetwood and Brougham Forum Discussion, Pics of the 77 CDV after paint in Past Cadillac Vehicle Discussion; Beautiful!...
  1. #16
    pompste is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 SEDAN DEVILLE-4.9 & 1978 SEDAN DEVILLE-425
    Jan 2007
    1,673
    Re: Pics of the 77 CDV after paint
    Beautiful!
  2. #17
    nebulosity's Avatar
    nebulosity is offline Cadillac Owners Fanatic
    Automobile(s): 1984 Cadillac Coupe DeVille
    Mar 2012
    San Jose, CA
    32
    283
    GORGOUS color!
  3. #18
    blueboy is offline Cadillac Owners Fanatic
    Apr 2005
    nashville, tn
    100
    What was your prepping work on this car? Hand rubbed or machine? If so what sander did you use ? Can you give us an idea of the total cost? Looks gorgeous!
  5. #19
    jsherid1 is offline Cadillac Owners Fanatic
    Automobile(s): 07 Escalade, 77 CDV, 13 CTS-V Wagon, 06 911, 87 928S4
    May 2009
    W Plano, TX
    189
    Car looks great! Try a Magic Eraser (gently as they are mildly abrasive) and plenty of water and you can get the top back to almost new condition if it is not torn. The bumper should be able to be straightened as time and budget permit.
  6. #20
    lacville78 is offline Cadillac Owners Fanatic
    Automobile(s): None at the moment
    Feb 2011
    30
    374
    Quote Originally Posted by blueboy View Post
    I didn't paint it, I just removed all the Chrome, Mirrors, Lock Cylinders, Grille, etc.
    The Car was taken to bare metal, and painted. It cost me $1700
    If you want to know how to do it yourself check out CSBUCKIN's Thread. A lot to learn in there.
    Quote Originally Posted by jsherid1 View Post
    Good Plan, I'll give it a try. Thanks.
  7. #21
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    That bumper damage is from hitting a high curb (I know). The top plate of the center section is bent. I have never tried to straighten them, just replace. The front center section can be straightened. The rest of the damage is in the brackets.
  8. #22
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,180
    I think it gives a little character. my 87 has a round dent in the front bumper corner like a softball hit it.
  9. #23
    Apr 2005
    nashville, tn
    100
    Would you mind giving us a little more info on your stripping to metal process please? I'm about to haver a go at Blueboy, my 1976 CDV. Thanks
  10. #24
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by deVille33
    Do you know how to straighten a tweaked front bumper? Mine is racked about 1/4 inch downward on the right side from when it got hit a few years ago. It wouldn't be a problem except I can't install my right fender filler. I could shove it back up to where it should be with a 2 foot J-bar on the frame to bumper brace on the right side, but it would drop back down.
  11. #25
    Sep 2009
    33
    4,180
    the front bumpers should be on pistons like the rear. Maybe the piston plate bent instead of compressing in?
  12. #26
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by outsider
    I looked at them when I crawled under it to try to readjust the right side chrome piece (need a new one because the bottom of it is bowed down). The pistons plates seem ok (nothing obviously messed up) and the bumper isn't shoved in or out. Maybe I could shim between the piston plate and the bumper and try to straighten it that way.
  13. #27
    Feb 2011
    30
    374
    I just removed all of the chrome/ trim etc, and re installed it. They took the paint off.
    They used a chemical called Aircraft Stripper, and sanded a bit for the primer to stick.
    If you decide to use that chemical, BE CAREFUL! People have died using it, albeit usually when they were using it in bathrooms to strip tubs.
    The fumes are what kills, the chemical itself will burn the skin, so wear gloves and work outdoors, and try not to breathe that crap.
    That being said, it is cheap and works well.
  14. #28
    Mar 2006
    1,493
    Quote Originally Posted by cadillac kevin View Post
    I have never tried it, but I have a theory. Disassemble the bumper and remove the top plate and place it on a wooden work table. Use a block of wood (placed over the distorted area) and a sledge hammer, or a heavy dead blow hammer. It may not get back to the original contour, but it should be very close. As I say, I haven't tried it, as yet, but it may be worth the effort.
  15. #29
    Dec 2010
    St. Louis, MO
    6,395
    The problem is there is no visible damage to the main bumper to fix. It's not dented or anything. It is twisted just enough that the right fender filler will not fit (it's ABS, so the bumper has to be perfectly straight). I've been on the hunt for a new bumper at the junkyards, but finding a bumper that has nicer chrome than mine is proving to be a challenge (mine has super light scratches on it (part of the finish?) and tiny pinpoint dimples in the finish.) I've also been looking at sub 1k parts cars (occassionally one will pop up that looks nice inside and out but has a bad trans or rear end or something)
  16. #30
    Sep 2009
    33
    4,180
    I would try shimming the bumper where it's bent and then tighten down the bolts. Over time it may unbend.
    If not, you could maybe try clamping the bumper down and trying to bolt a pry bar like apparatus to the bent section and pry it up. I dunno, but it should be able to be straightened!
  17. Remove Advertisements
