Opera & Cornering lights? - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 45
Like Tree4Likes
1985-1996 Fleetwood and Brougham Forum Discussion, Opera & Cornering lights? in Past Cadillac Vehicle Discussion; i guess so, anyone that have any exoerience on replacing that ?...
  1. #16
    Jeppi94's Avatar
    Jeppi94 is online now Cadillac Owners Fanatic
    Automobile(s): 1989 Cadllac Brougham
    Jul 2013
    Gothenburg, Sweden
    22
    166
    Re: Opeara & Cornering lights?
  2. #17
    j2rossit is offline Cadillac Owners Enthusiast
    Automobile(s): 85 FW Brougham, 68 Wildcat 'vert, 92 & 96 Roadmaster Wagons
    Jan 2011
    Southern Ontario
    934
    They are a pain. Need a steering wheel puller. You have to be careful with the telescoping shaft as you remove it since the parts can fall all over the place.
  3. #18
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    40
    1,150
    What?! You don't need a steering wheel puller. You can gain access to it by removing lower dash cover and you'll see the wires. I'll scan a diagram so you can see. All I did on mine was spliced it in. The other switch is still there on the column, one that failed
  5. #19
    Jan 2011
    Southern Ontario
    934
    I thought he was thinking of replacing the turn signal switch.
  6. #20
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,469
    I thought it was part of the turn signal switch inside the column too, all I've ever heard of was digging in thru the column from the wheel side to replace it to fix the problem.
  7. #21
    1980coupe's Avatar
    Jan 2009
    El Paso, TX
    40
    1,150
    You guys are talking about the lever on the column, lol. This is down further on the column itself, down underneath dash. Sorry, I haven't scanned diagram, cannot locate my book...
  8. #22
    1980coupe's Avatar
    Jan 2009
    El Paso, TX
    40
    1,150
    itis the image, it is the one identified as C105- that is your cornering switch
  9. #23
    Jun 2003
    Canada
    6,469
    Quote Originally Posted by 1980coupe View Post
    Not lever, switch. I guess things changed since your year. I looked it up in my manual and it says cornering lamp switch in steering column in turn-hazard switch and the first steps of replacing it is to remove steering wheel, ignition lock and everything else from the top part of the column.
  10. #24
    Smobien is offline Cadillac Owners Member
    Automobile(s): 91' Brougham 5.7
    Aug 2013
    9
    Question about the B pillar lights.
    Can anyone post a pic of a repair of the EL light they have done?
    To gain access to the light you have to remove the B pillar interior components correct?
  11. #25
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by Smobien
    Correct.
  12. #26
    Jan 2011
    Southern Ontario
    934
    Quote Originally Posted by brougham View Post
    Yeah, in 85 the turn signal switch is deep in the column and needs the removal of the wheel to get at it.
  13. #27
    Jeppi94's Avatar
    Jul 2013
    Gothenburg, Sweden
    22
    166
    ok, i've just ordered a Workshop Repair manual for my 1989 Brougham, i will wait until that comes before i do anything. But in general, it sounds like a rather tricky job?
  14. #28
    Jeppi94's Avatar
    Jul 2013
    Gothenburg, Sweden
    22
    166
    I've solved and fixed the problem with my cornering lights...there were no bulbs in them x) They work perfectly now!
  15. #29
    1980coupe's Avatar
    Jan 2009
    El Paso, TX
    40
    1,150
    Lmao
  16. #30
    Pitoya is offline Cadillac Owners Member
    Automobile(s): Brougham -90 and Brougham -89
    May 2013
    Sweden
    7
    Quote Originally Posted by Jeppi94 View Post
    Nice one, I had the same no bulb problem on my 1990 borugham.
    To you guys trying to remove the opera lights, it's very easy, just remove interior covers and loosen the 4 nuts to the outer chrome covers and opera lights. Be careful not to drop the nuts though, I did drop one into the B-pillar and it was never seen again. I did not do an EL-replacement since I'm unfortunantly very low on cash right now. Instead I replaced the EL-tape with LED strips and it is not nearly as good looking as EL but I had some laying around the garage so why not put them to some use.
  17. Remove Advertisements
