remove drivers kick panel
Results 1 to 3 of 3
1985-1996 Fleetwood and Brougham Forum Discussion, remove drivers kick panel in Past Cadillac Vehicle Discussion; Hey guys, I was wondering how do you remove the hood release from the kick panel? I would like to ...
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    Hey guys, I was wondering how do you remove the hood release from the kick panel? I would like to try my hand at custom kick panel speaker enclosures (using junkyard kick panels of course) but have no idea how to get the hood release cable out of the kick panel.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,618
    Which caddy? If the 87, the cable will have to come all the way out to get the panel out. I just swapped mine, its easy-ish but you cant get it out without pulling it through from the engine to the cabin. The panel has one screw and the door sill comes off too. Its bolted to the firewall on the engine side also and the little bolt can be kinda hard to get to.
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Re: remove drivers kick panel
    The hood release cable is all one piece, so the only way to remove it from the kick panel would be to remove it from the hood latch.
    To remove the release cable, you have to disengage it from the latch assembly. Then you remove the screws holding the release cable to the to the kick panel, the sill screws and sill plate, and the screws holding the shroud to the kick panel. Then you need to remove the parking brake bracket and slide the cable and shroud through the opening in the kick panel. There's a retaining clip, and you snap the cable out of it and pull it out in the release direction.
    You should block the release mechanism, so that the hood cannot close (you won't get it open). You could probably put a shortened cable between the radiator and grill, and make the hood release accessible through the slats in the grill.
