Wheel bearing install question.
Results 1 to 4 of 4
1985-1996 Fleetwood and Brougham Forum Discussion, Wheel bearing install question. in Past Cadillac Vehicle Discussion; So, I've got a bad bearing on the front ps side. I went ahead and bought new bearings and races,grease ...
    lacville78 is offline Cadillac Owners Fanatic
    Automobile(s): None at the moment
    Feb 2011
    30
    374
    So, I've got a bad bearing on the front ps side. I went ahead and bought new bearings and races,grease seal, and the race driver.
    My question is, how do I tighten the castle nut to the proper tightness.
    I understand too tight is bad, and too loose is bad. It is supposed to be hand tight but how hard should I tighten it?
    Stupid question, I know. But I'd rather look dumb on here, than look dumb on the side of the road.
    Also, I've already taken it all apart, so I can't just count the number of turns when taking it off.
    Thanks,
    Tom.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,984
    Re: Wheel bearing install question.
    Tighten with a pair of Channelocks as you turn the rotor. As the drag increases, the bearing seats. You will feel the difference. Stop tightening, back off the nut to the next hole. Cotter pin, cap, done.
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    You tighten the nut while spinning the wheel. I believe the SM rate was 34 ft/lbs, if your using a torque wench. Then you back off an 1/4 turn, then tighten until the nut cage aligns with the cotter pin hole in the spindle.
    Feb 2011
    30
    374
    Thanks guys!
    I got it done today, no more roaring!
  7. Remove Advertisements
