79 sdv radio help!!
Results 1 to 14 of 14
1985-1996 Fleetwood and Brougham Forum Discussion, 79 sdv radio help!! in Past Cadillac Vehicle Discussion; Hi there! So I'm looking for the original 8track radio for my caddy, I found one but my concern is ...
    vicello93's Avatar
    vicello93 is offline Cadillac Owners Fanatic
    Automobile(s): 1979 sedan deville
    Apr 2013
    107
    79 sdv radio help!!
    Hi there! So I'm looking for the original 8track radio for my caddy, I found one but my concern is the mess they did with the wires years ago when they installed the aftermarket radio. I know ill have to buy the harness to plug the 8track, but with the wires I have can u guys tell me if I can just cut and put the wires together and if they will match the color of the original? These are the wires..
    pompste is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 SEDAN DEVILLE-4.9 & 1978 SEDAN DEVILLE-425
    Jan 2007
    1,673
    Re: 79 sdv radio help!!
    Are you sure your '79 had the 8-track in it? My '78 Deville has the original stereo radio combined with the "cassette tape" player.
    Maybe they still offered the 8-track in 1979.
    Others will chime in about your wiring questions.
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    39
    1,150
    If the radio is from another caddy, then yes. Just match the colors and you're good to go. Cadillac offered a variety of radio options, so yes an 8 track radio was an option.
    I have the diagram and can tell you what wires go where, if you need assistance.
    The two top are rear speaker wires, next tanish and grey are front either left or right followed by the light green and green wires.
    Orange is power constant, pink is antenna, yellow is power switched, grey is illumination, brown dimmer, black ground Just going off by memory here...
    This is a good website for wiring
    www.the12volt.com
    Search Cadillac and find year, model and there you go.
  5. #4
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Yep. Mine has the 8-track.
    They also offered:
    AM/FM stereo only
    AM/FM with cassette
    AM/FM with cassette and CB
    If the one you found has a digital display (amber color), it is correct for your car.
    If it has the analog tuner, it came from a '78 or earlier.
  6. #5
    vicello93's Avatar
    Apr 2013
    107
    That's great! Thank you all for the replies! I just need To buy the connector for the radio because it doesn't come with it.. But eBay has it so it will help
  7. #6
    Feb 2003
    california
    69
    6,611
    Most GM radios of that era had the wiring diagram engraved on the radio cover. And that wiring color code was the same from about 76 thru 85 on most if not all GM cars.
  8. #7
    Bro-Ham's Avatar
    Bro-Ham is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Sedan deVille d'Elegance
    Oct 2005
    Sarasota, FL
    49
    4,152
    Quote Originally Posted by pompste View Post
    1979 was the first year the cassette tape player was a Cadillac factory option, 8-track was also still available.
    1979 was also the first year the ETR radio became standard on all Cadillacs. The ETR radio first appeared as an option on 1978 Fleetwood Brougham and Seville.
    I'm curious to know what kind of radio is in the car now? Was the trim bezel altered to fit the aftermarket radio? If so then you may likely need to consider a replacement which seem to be fairly commonly available on eBay.
    A factory service manual may also have answers on the wiring.
    Good luck and have fun listening to stereophonic excellence on the magic of high fidelity 8-track tapes in your 79 Cadillac!
  9. #8
    vicello93's Avatar
    Apr 2013
    107
    Ok so I ended up buying a cassette/radio unit , it was a good deal so I jumped on it also bought the connectors to plug it in. Now I'm anxious to get it!
    Quote Originally Posted by Bro-Ham
    It has a digital, crappy radio, Optimus brand. They used the old radio brackets to install. Apparently it fitted right in.
    Haha I wish I have gotten the 8track... Maybe in the future when I come across a good deal lol
  10. #9
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by vicello93 View Post
    optimus brand radio? got a pic? Haven't seen too many of those lately...something about they sucked
  11. #10
    Feb 2003
    california
    69
    6,611
    Optimus? Isn't that the RADIO SHACK brand? and you used the words Cassette 8 track and the future in the same post. I think "Back To The Future" is more accurate!
  12. #11
    vicello93's Avatar
    Apr 2013
    107
    Quote Originally Posted by carnut
    Hahah
  13. #12
    vicello93's Avatar
    Apr 2013
    107
    Update! Radio and in and is installed and working. Speakers work but sound goes on and off on the front left speaker sometimes. But overall I'm quite happy
  14. #13
    Dec 2010
    St. Louis, MO
    6,395
    I'm guessing bad connection at the radio or speaker itself, worn out speaker, or an internal problem with the radio (i.e. bad channel). Did you have this problem prior to swapping the radio?
  15. #14
    vicello93's Avatar
    Apr 2013
    107
    Quote Originally Posted by cadillac kevin
    No it was working fine before, but I went for a drive and the radio mends itself after three minutes and works fine. Go figure but yeah might be the radio because I could find the connector for the back so I welded every wire to the right place. It works fine but after three minutes lol
  16. Remove Advertisements
