Brake problem on 96 Fleetwood
Results 1 to 14 of 14
Like Tree3Likes
  • 1 Post By turbojimmy
  • 1 Post By BIGBEN11
  • 1 Post By HUF
1985-1996 Fleetwood and Brougham Forum Discussion, Brake problem on 96 Fleetwood in Past Cadillac Vehicle Discussion; Hello all my rear brakes do not work at all and my abs light is on and had been on ...
    BIGBEN11 is offline Cadillac Owners Member
    Automobile(s): 1985 fleetwood coupe & 1996 fleetwood brougham
    Aug 2012
    Knoxville
    15
    Hello all my rear brakes do not work at all and my abs light is on and had been on since I bought the car, I took apart the brakes and cleaned the cylinders but noticed I'm not getting fluid, I thought maybe the porportioning valve?? Any body have an idea??
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,931
    Re: Brake problem on 96 Fleetwood
    Can you please elaborate on the EXACT steps you did to "took apart the brakes and cleaned the cylinders"? Back brakes?
    Aug 2012
    Knoxville
    15
    Yes back brakes, I took the drums off took the springs off, pulled off the rubber boots on the cylinders pulled out the caps and lightly sanded the cylinder just to make sure they had a smooth surface, put back together and tried to bleed but am not getting fluid to rear
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,613
    These rear brakes are just a pain. Technically, you should have a leak if you cant get fluid to the rear.
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    Quote Originally Posted by csbuckn View Post
    And if you have no brakes at all. There has to be a massive leak somewhere.
    Aug 2012
    Knoxville
    15
    Quote Originally Posted by turbojimmy View Post
    I don't believe there's a leak cause the fluid has been at the same level for months
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Quote Originally Posted by BIGBEN11 View Post
    The fluid is at the right level currently? But there's no braking action at all?
    Aug 2012
    Knoxville
    15
    Yes the fluid is at proper level and there is zero braking action on rear, front works fine, my car seemed to not stop as good as it should and my front white walls seemed to get dirty real quick so I jacked the rear up put her in drive and applied the brakes and the wheels just keep spinning as I suspected
    Jan 2008
    Minneapolis
    5,613
    Either your master cyl is not working right, your prop valve is jammed to one side or you have a leak. I bet, if you hooked up a vacuum pump to the rear cylinders, it wont hold a vacuum meaning you have a leak. My guess is that it leaked out under the C-pillar or A-pillar and has been dry for a while so you dont really notice any fluid.
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,112
    Something might happen inside of ABS hydraulic modulator. A valve does not open and let fluid flow to the rear brakes. I would disconnect the rear brake lines from the modulator to make sure there is fluid coming out of the valve responsible for both rear brakes.
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    The front pads on my '96 were down to metal when I first got it so I replaced them. A couple weeks later they were down to metal again and they always smelled hot. Being new to Fleetwoods I figured they just didn't stop very well, but investigated anyway. Turns out the previous owner must have replaced either a wheel cylinder or a leaky line without bleeding the brakes. I had no braking action in the back at all. I replaced the shoes to no avail. Finally I bled the air out of the rear and that was the trick. I couldn't believe how well the car stopped once all 4 wheels had brakes.
    Cadillacboy likes this.
    Aug 2012
    Knoxville
    15
    Update for those with similar problem it was the porportioning valve... I now have rear brakes
    turbojimmy likes this.
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,390
    Sorry ,I have not given you any idea about your problem but appreciate your feedback on your brake issue
  16. #14
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,112
    Thanks for the update. It is nice to see people not only seeking solutions but also sharing ones.
    MrHolland likes this.
  17. Remove Advertisements
