94 Fleetwood Hearse windows won't go down
Results 1 to 5 of 5
1985-1996 Fleetwood and Brougham Forum Discussion, 94 Fleetwood Hearse windows won't go down in Past Cadillac Vehicle Discussion; Help! It's hot and it smells funny in there (no a/c either!) Does anyone know where in the fuse panel ...
    Faith76's Avatar
    Faith76 is offline Cadillac Owners Enthusiast
    Automobile(s): 89 Sedan DeVille, 90 Fleetwood, 94 Fleetwood Hearse
    Jul 2013
    Fredonia, NY
    41
    557
    Help! It's hot and it smells funny in there (no a/c either!) Does anyone know where in the fuse panel the fuse for the windows are, or have any other suggestions? Maybe a fuse diagram? Thanks!
    jamespowers is offline Cadillac Owners Connoisseur
    Automobile(s): 1986 Brougham, 1975 Eldorado, 2008 Escalade
    Mar 2013
    1,100
    Re: 94 Fleetwood Hearse windows won't go down
    Quote Originally Posted by Faith76 View Post
    There isn't a diagram in the cover?
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    They don't even try? Could be lots of things.
    You should get a FSM or subscribe to alldatadiy. The info alldata has for the '94+ Fleetwoods is fairly complete.
    Feb 2003
    california
    69
    6,679
    Not controlled by a fuse! windows are wired thru a circuit breaker. Most likely you have no power to the master switch on the drivers door. Pull the switch up and partially out of the arm rest and with a test light, confirm you have voltage to the switch.
    Faith76's Avatar
    Jul 2013
    Fredonia, NY
    41
    557
    Thanks, as soon as it quits raining here, I'll go try that.
    Quote Originally Posted by carnut View Post
  8. Remove Advertisements
