Cherie's '84 Coupe DeVille Project - Page 13
Page 13 of 25 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 181 to 195 of 370
Like Tree406Likes
1985-1996 Fleetwood and Brougham Forum Discussion, Cherie's '84 Coupe DeVille Project in Past Cadillac Vehicle Discussion; Caddy update: They noticed the distributor wasn't bolted down securely and the timing was changing causing the power loss. Now, ...
  1. #181
    nebulosity's Avatar
    nebulosity is offline Cadillac Owners Fanatic
    Automobile(s): 1984 Cadillac Coupe DeVille
    Mar 2012
    San Jose, CA
    32
    283
    Re: Cherie's '84 Coupe DeVille Project
    Caddy update:
    They noticed the distributor wasn't bolted down securely and the timing was changing causing the power loss. Now, I know that we couldn't figure out how the distributor is supposed to be bolted down, so I'm not in the least bit surprised they found that out (although I didn't think it was the primary cause for loss of power).
    Does anyone know how the distributor is supposed to be fixed in place after you set the timing? It seemed like someone had RTVd the thing in before I took the distributor base out, and I didn't RTV it back in because I didn't think that was the official way to do it.
    Ideas?
  2. #182
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    Is there not a clamp and bolt?
    nebulosity likes this.
  3. #183
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,620
    There should be a bolt hole close by that would be used to bolt down the distributer clamp.
  5. #184
    nebulosity's Avatar
    Mar 2012
    San Jose, CA
    32
    283
    There is a threaded rod with a washer and a nut UNDER the distributor base, but it's unclear to use how it does anything to keep the distributor from rotating... as far as we can see, it only keeps the distributor in the hole. There's supposed to be a clamp? When I took the caddy originally to be checked out at a place in san jose called Robbie's auto, they returned the car to me without the distributor bolted into the hole... it was just sitting in there.
  6. #185
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    There should be a bolt, or perhaps a nut on a stud, and a clamp to hold that distributor in place. It's engineered in a way that no human could possibly see or touch it. The engineers still giggle themselves to sleep at night. When you have the right parts, you'll need a distributor wrench (a 90-degree wrench) to get on the bolt/nut and even then you can get like 1/100" of a turn at a time out of it. It would take hours to tighten properly. Or at least that's how I recall them. YMMV.
  7. #186
    nebulosity's Avatar
    Mar 2012
    San Jose, CA
    32
    283
    Quote Originally Posted by turbojimmy View Post
    There is a nut on a stud. How the heck does it keep the distributor in place?
  8. #187
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    8,026
    You're missing the clamp.
    turbojimmy and nebulosity like this.
  9. #188
    nebulosity's Avatar
    Mar 2012
    San Jose, CA
    32
    283
    What's it look like? I could probably go pull one off at the Pick-n-Pull.
  10. #189
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    40
    1,150
    Yeah, you can get one from the JY...
    http://www.google.com/search?hl=en&s...B6bbyQGDjIDAAw
    turbojimmy likes this.
  11. #190
    BigCadMan_1's Avatar
    BigCadMan_1 is offline Cadillac Owners Fanatic
    Automobile(s): 93 Eldorado 4.9, 95 Fleetwood 5.7 LT1.
    Sep 2011
    Montreal, Canada
    445
    You need the part numbered as 17.
  12. #191
    nebulosity's Avatar
    Mar 2012
    San Jose, CA
    32
    283
    Caddy update:
    I found the funny shaped washer (i.e. clamp) that holds the distributor in place. Now I need a distributor wrench.
    Because of work, I haven't been able to go get the Caddy yet, but we're definitely going down to get the caddy in the morning. I need to test drive it to make sure it'll be able to handle at least 40mph. Once we feel comfortable that the caddy is in decent shape to drive up the 17, we're going to take it to get smogged.
    I have no idea what tomorrow will bring. The uncertainty makes me worry a bit. :/
  13. #192
    greencadillacmatt's Avatar
    greencadillacmatt is offline Cadillac Owners Connoisseur
    Automobile(s): '09 Dodge Challenger RT, '84 Cadillac CDV, '94 Jeep GC LTD
    Sep 2008
    Otsego,Michigan
    27
    2,239
    Quote Originally Posted by nebulosity View Post
    Fingers crossed for you! Definitely hoping that everything works out. I'm a huge fan of the '84 Coupes, and it always sucks seeing one down. BEST OF LUCK!
  14. #193
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    I wish you luck but I would bet money a poor running car will not pass smog.
    I always tell my girlfriend to wear something sexy when she takes her old clunkers in for inspection. Surprisingly it works and they always miss the medium sized rust holes that I didn't feel like fixing. I tell her to keep talking and joking with the guys while they are under the car to mess up their train of thought lol. Probably irrelevant for a smog check.
  15. #194
    nebulosity's Avatar
    Mar 2012
    San Jose, CA
    32
    283
    Quote Originally Posted by greencadillacmatt
    Thanks!! We need it. We'll do our best and keep you guys updated.
  16. #195
    nebulosity's Avatar
    Mar 2012
    San Jose, CA
    32
    283
    Caddy update:
    Took the Caddy for a test drive and to the gas station for a little more gas (first gas station fillup in years!!). The Caddy drove quite nicely! A lot like I remember it. Not a race car obviously, but it absolutely did not struggle or backfire, even on modest hills. I got up to 45mph no problem whatsoever.
    The only issue now is that it still needs a new valve cover gasket and one of the holes probably need to be re-tapped. Since I apparently screwed it up last time, Im just gonna let the guys at Larrys take care of it. They wot be able to get to it for a week or so, but theres no hurry since my moving permit is good for 60 days.
    We're on our way to go replace the battery because it doesnt really hold a charge anymore. Then we go pick up the calve cover gasket at winchester auto, put in the new battery and leave the new gaskets in the Caddy.
    It was throwing some codes at first: 12, 15, 23, 30, 52, but after we took out the battery (and then had to put it back in to move the car, lol) effectively clearing the codes, I was getting a 16 and a 52. I left my shop manual at home by accident, so I cant remember what all the codes are. Some are probably related to the fact that the auto shop guy played with the distributor, and I expect those codes wont stay long after we get the new battery in, Ill clear the codes, start it up and try again.
    First fillup at the gas station in years...
    ....... hey, this is a loud sound. What the heck is it? A valve? o_O
    mitch2264 likes this.
  17. Remove Advertisements
