Location of the MAP sensor in a 1989 Brougham ?
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Jeppi94
1985-1996 Fleetwood and Brougham Forum Discussion, Location of the MAP sensor in a 1989 Brougham ? in Past Cadillac Vehicle Discussion; Hello, i'm having a code for the MAP sensor and i'm about to replace it. But i'm not able to ...
    Jeppi94's Avatar
    Jeppi94 is offline Cadillac Owners Fanatic
    Automobile(s): 1989 Cadllac Brougham
    Jul 2013
    Gothenburg, Sweden
    23
    173
    Hello, i'm having a code for the MAP sensor and i'm about to replace it. But i'm not able to find it anywhere near the intake hoses under the hood, where i guess it shall be?
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,620
    Re: Location of the MAP sensor in a 1989 Brougham ?
    Its low on the engine block near the oil pan. Not sure what side its on but you will probably have to get to it from underneath.
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    On the 307 that is in your '89 Brougham, the MAP sensor is located near the top of the engine, and is on the passenger side of the engine compartment, near the A/C Accumulator (the large silver cylinder). The MAP sensor is a little black square, and underneath it there is a green connector and very small vacuum line.
    If you can't find it, I can post a picture of it and it's location.
    Jeppi94's Avatar
    Jul 2013
    Gothenburg, Sweden
    23
    173
    Thank you a lot! i would be delighted if you could post a picture!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    A factory service manual would be a wise investment:
    http://www.ebay.com/itm/1989-Cadilla...af499e&vxp=mtr
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,198
    Sven you're still here? How about in addition to the pics requested by Jeppi94 you share some pics of your Caddy too? I miss seeing it!
    sven914's Avatar
    Dec 2008
    4,256
    Here are the pictures. The MAP sensor is circled in red.
    Quote Originally Posted by outsider View Post
    I never really left, but am being very choosy as to when and where I post. I don't really have any new pictures of my car to post, but maybe I'll take some.
    Jan 2008
    Minneapolis
    5,620
    I was thinking about the knock sensor. My bad, hope you didnt get under your car.
    Jeppi94's Avatar
    Jul 2013
    Gothenburg, Sweden
    23
    173
    Thankyou very much for the pictures Sven914, and csbuckn, no i did not yet go under my car, but i suspected that you might have ment the nock sensor, gonna replace it too however and after that, i shoulld have no more codes and my Brougham should be running perfectly.
    The guy i bought it from didn't know anything about how to diagnose the car and strangely he didn't care too much about the "CHECK ENGINE" light. Therefore i got the car very cheap, it had codes for the O2 Sensor, the MAP sensor and the Nock Sensor. However the engine and transmition runs flawless! (go to my profile and check it out, there's an album with some pic's on it)
    Jeppi94's Avatar
    Jul 2013
    Gothenburg, Sweden
    23
    173
    if anyone could post a picture of the Knock sensor too, that would be very kind
    sven914's Avatar
    Dec 2008
    4,256
    If your are getting a code 43, there might not be an issue with your knock sensor. The 307 uses different coded than other GM engines, because it is a computer controlled carburettor.
    According to my service manual code 43 is for the Electronic Spark Control (ESC) circuit. To correctly diagnose it, you need a scanner that can display the engine timing and Knock Retard.
    The knock retard should be at zero with the engine idling at normal operating temperature. If it is, then have someone tap on the lower engine block and see if the knock retard increases. If it does, the issue is intermittent or has otherwise been resolved. If the retard doesn't increase, either the knock sensor or the ESC is malfunctioning.
    If the knock retard is not close to zero, then there may be a bad connection between the ESC and ECM; you could try unplugging it and cleaning the terminals. If that doesn't work, either the ESC or the ECM is faulty.
    The Electric Spark Control is located on the firewall, directly behind the distributor; it's a black square with five wires coming off it. The yellow wire goes to the ECM and the blue wire goes to the knock sensor.
    The knock sensor should be located on the side of the engine, near the oil pan but screwed into the block. I don't have a picture of it, but you should be able to find it by following the blue wire.
    The ECM is located behind the glove box, and can be accessed if you remove the glove box liner.
    Jeppi94's Avatar
    Jul 2013
    Gothenburg, Sweden
    23
    173
    I can now add that i've literally fixed the problem with my MAP sensor, it was a bad electrical contact which was loos that made it not to function, it was that simple!!
    talismandave likes this.
  15. Remove Advertisements
