Obdi or obdii ?
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By jamespowers
1985-1996 Fleetwood and Brougham Forum Discussion, Obdi or obdii ? in Past Cadillac Vehicle Discussion; just something i was thinking lastnite,i got a 96 fleetwood, i had changed out my pcm/ccm out of a 94 ...
    85 FLEETWOOD COUPE's Avatar
    85 FLEETWOOD COUPE is offline Cadillac Owners Fanatic
    Automobile(s): 96 CADILLAC FLEETWOOD BROUGHAM
    May 2011
    GEORGIA
    463
    Obdi or obdii ?
    just something i was thinking lastnite,i got a 96 fleetwood, i had changed out my pcm/ccm out of a 94 fleetwood, so would i ave to use the obdII still bacause its a 96 or do i use the obdI because i switched stuff out from a 94 witch is a obdI????
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    Re: Obdi or obdii ?
    So you put a '94 PCM in a '96 Fleetwood? And it works?
    May 2011
    GEORGIA
    463
    Re: Obdi or obdii ?
    Well i had the 1 under the hood flashed before installing in the 96, should i have keep the 1 in the trunk the 96 1 or leave the 94 in there? The car runs, i had my steering column out the 94 to
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,895
    Re: Obdi or obdii ?
    The 96 OBD2 PCM is a completly different part number than the 8051 OBD1 PCM used in the 94-95 B/D cars. You need a 96 PCM.
    May 2011
    GEORGIA
    463
    Re: Obdi or obdii ?
    So you saying if i used the obdii it wont show correct codes? But i flashed the pcm shouldnt that matter????
    But some 1 told me if i used the pcm and the ccm it would work on my 96
    Sep 2006
    Ontario, Canada
    44
    7,895
    Re: Obdi or obdii ?
    The OBD1 PCM is different, even if flashed. It uses a different chip set, and looks for different resistance on the knock sensors. You need a 96 PCM in a 96 (and a 94/5 in a 94/5).
    People will tell you lots of things. If a guy tells you he's Batman... it might even be true.
    jamespowers is offline Cadillac Owners Connoisseur
    Automobile(s): 1986 Brougham, 1975 Eldorado, 2008 Escalade
    Mar 2013
    1,100
    Re: Obdi or obdii ?
    Quote Originally Posted by jayoldschool View Post
    I am Batman.
    nebulosity likes this.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by jamespowers
    I am Batman.
    No, I'm batman. We've never been seen in the same room together. Coincidence? I think not!
    silverfox103's Avatar
    silverfox103 is offline Cadillac Owners Fanatic
    Automobile(s): 96 Fleetwood & 07 CTS, 94 Roadmaster Wgn & 94 Caprice Wgn
    Aug 2012
    Littleton, NH & St. Simons, GA
    67
    396
    Re: Obdi or obdii ?
    I agree with Jay, it makes no sense to do that. The 96 is made to run on an OBDII.
    Tom C.
    Mar 2013
    1,100
    Re: Obdi or obdii ?
    Quote Originally Posted by cadillac kevin View Post
    No I am Batman. I have been seen in the same room as Batman---because I was smart enough to use Alfred as a decoy.
    May 2011
    GEORGIA
    463
    Re: Obdi or obdii ?
    Im sorry it is a 96 pcm i just had it flashed,the ccm is a 94 along with the steering column i had installed would that matter or should i plug up back the 96 ccm in the trunk?
    This guy told me to use the ccm because i was going to use the 94 steering column with the 94 original key,does this makes sense to you guys, i had to bypass the column but it starts up
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Re: Obdi or obdii ?
    That makes more sense. I *think* the CCM is the same. If you've bypassed the PASS KEY system, and it works, why mess with the CCM now?
    May 2011
    GEORGIA
    463
    Re: Obdi or obdii ?
    I did everthing at 1 time, i did the ccm becaus i thought the 94 original key would read it and would start
  16. #14
    May 2011
    GEORGIA
    463
    Re: Obdi or obdii ?
    So now my question is would the obdii reader still read if it had the 94 ccm in the trunk or dont matter?
  17. #15
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Re: Obdi or obdii ?
    It doesn't matter. Only OBD-II powertrain codes are reported on the '96 and accessed via the OBD-II port. Body codes are the old style, like on the earlier years and can be accessed through the HVAC module.
  18. Remove Advertisements
