air shock pump
Results 1 to 4 of 4
1985-1996 Fleetwood and Brougham Forum Discussion, air shock pump in Past Cadillac Vehicle Discussion; I just recently replaced the water pump, spark plug wires (and plugs) gas line, and air shocks in the rear. ...
    soleman10 is offline Cadillac Owners Member
    Automobile(s): 1991 fleetwood brougham commercial chassis
    Mar 2010
    35
    air shock pump
    I just recently replaced the water pump, spark plug wires (and plugs) gas line, and air shocks in the rear. Now I find my air pump isn't working. I'm thinking I'll need to replace it, but the guy at the parts store suggested checking for a blown fuse first. He mentioned "inline" fuses as well as block fuses but wasn't clear on location. Any input? I really don't want an air nipple behind the gas filler door to manually fill the shocks. This is a 91 brougham hearse.
    Thanks in advance
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    Re: air shock pump
    On my '94, and I think the older ones are the same, there are 2 fuses. One is in the interior fuse panel and the other is under the hood. Though the problem is rarely the fuses. Did it work before the work was done? They're fairly easy to troubleshoot. I'd start by grounding the pump relay to see if it runs and go from there. If the pump runs, get a wiring diagram and start hunting! In my experience, it's usually a wiring issue rather than the pump itself.
    silverfox103's Avatar
    silverfox103 is offline Cadillac Owners Fanatic
    Automobile(s): 96 Fleetwood & 07 CTS, 94 Roadmaster Wgn & 94 Caprice Wgn
    Aug 2012
    Littleton, NH & St. Simons, GA
    67
    387
    Re: air shock pump
    If you should need one, they're not expensive:
    http://www.ebay.com/itm/190531064126...84.m1423.l2649
    Tom
  5. #4
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Re: air shock pump
    My brother got one of those for his Roadmaster. It's slightly different. You use that motor but keep the stock compressor head. For $55 it's well worth the little bit of extra work.
  6. Remove Advertisements
