Results 1 to 11 of 11
Thread: 1989 Cadillac Brougham Alternator change
    Jeppi94's Avatar
    Jeppi94 is offline Cadillac Owners Fanatic
    Automobile(s): 1989 Cadllac Brougham
    Jul 2013
    Gothenburg, Sweden
    22
    173
    Question 1989 Cadillac Brougham Alternator change
    Hello my fellow humans!
    Now, i was out driving and the "NO CHARGE" light came on suddenly. Now, my dad was 90% sure that my alternator have gone broke. I have had a look on some websites for a new alternator but they all seem to have V-belts without any cog's, my alternator is driven by something that looks like a timing belt with cog's. Anyhow, to remove the alternator i will have to untighten the drive belt and where and how do i do that on the VIN Y Olds 307 5.0L ?
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    Quote Originally Posted by Jeppi94
    No charge light could be loose belt or a bad diode in the alternator.
    The alternators with the V belt without cogs is for a serpentine setup (for chevy motors)
    Yours will have a pulley like the one that is already on yours. Check oreillys or carquest for an ac delco alternator for your car.(I do not trust the "house brand" alternators). You will want the one with the highest amp rating (GM had a 67, 78, and either approx. 90 or 100 amp alternator in the 80s.)
    As for how to loosen the belt to change it, IIRC from when I did my alternator on my 307, you simply loosen the bolts that hold it in place and it swings down.
    Jeppi94's Avatar
    Jul 2013
    Gothenburg, Sweden
    22
    173
    Re: 1989 Cadillac Brougham Alternator change
    Ok, thx for your reply!
    I indeed have some belt squeak at start up sometimes, but i i've felt on the generator belt and it's rather snug as it should be. I wonder, is there anyway you can check the alternator with a multimeter?
  5. #4
    SafariOne is offline Cadillac Owners Fanatic
    Automobile(s): 1981Cadillac Fleetwood Brougham D'Elegance Coupe m
    Mar 2008
    British Columbia
    392
    If I recall these alternators have an internal regulator that can also be the problem. These parts are also available if you decide to do it yourself. A new alternator is by far the easier way but each to their own. When I pulled mine out I cleaned it all up and spray painted it gloss black to match the AC Compressor.
  6. #5
    Jeppi94's Avatar
    Jul 2013
    Gothenburg, Sweden
    22
    173
    I had a friend of mine who's really good at electronics and cars to make a diagnostic fail search on the alternator and it came out to be a burnt out set of doids. So i've bought a new set of diods and a regulator as well. Way cheaper than replacing the entire alternator.
  7. #6
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Quote Originally Posted by cadillac kevin
    Probably not many of those in Sweeden .
  8. #7
    Mar 2008
    British Columbia
    392
    You make a very good point there.
  9. #8
    Jeppi94's Avatar
    Jul 2013
    Gothenburg, Sweden
    22
    173
    sadly, neither oreillys nor carquest ship international. But i found a Swedish company who got the regulator and parts i need. And yes, the 80's Cadillac's especially the Brougham, is very rare here in Sweden, personally i had never seen one for real before i bought mine. But it's the straight opposit with 50's and 60's Cadillac's, they are everywhere and i mean everywhere. After USA and Cuba, Sweden is the country with the largest ammount of classic cadillac's.
  10. #9
    Sep 2010
    East Boston MA.
    29
    26,323
    For future reference, www.rockauto.com ships internationally, and the site has an option to display prices in local currency.
  11. #10
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,477
    It shouldn't be too hard to find a local company that either sells the alternator you need or can rebuild the one you have. Those GM alternators were used for a lot of applications including a lot of commerical type trucks that would have made it overseas.
  12. #11
    Jeppi94's Avatar
    Jul 2013
    Gothenburg, Sweden
    22
    173
    I drove the car a few miles on battery to my friends dad who offered to make a diognostic search and rebuild the alternator. it's showed out to be a few diodes that have goe broken. So i've ordered a new set of diodes and a regulator from a local site. The alternator is a 105A Delco-Remy. Soon i will be rollin again!
  • You may not post replies
