Help my 94 fleetwood won't start !! Passkey fault light steady on - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Like Tree3Likes
1985-1996 Fleetwood and Brougham Forum Discussion, Help my 94 fleetwood won't start !! Passkey fault light steady on in Past Cadillac Vehicle Discussion; Originally Posted by HUF I do not know whether you checked out the link I have found for you, but ...
  1. #16
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    Re: Help my 94 fleetwood won't start !! Passkey fault light steady on
    Quote Originally Posted by HUF View Post
    I do not know whether you checked out the link I have found for you, but it looks the dealer will just replace the ignition switch. That is something you could do yourself.
    And it would be a waste of time and money if you've already correctly bypassed the VATS.
  2. #17
    Fleetwoodboule's Avatar
    Fleetwoodboule is offline Cadillac Owners Member
    Automobile(s): 1994 fleetwood brougham
    Jun 2013
    Montreal Canada
    29
    18
    the problem isnt the ignition,as I have already bypassed it and as it turns out the problem is the module itself, i gotta replace it but GM has discontinued that part, so i gotta find a used one now and have it interrogated to find out the new key number so I can replace the resistor(dont want to pay 100$ for a new key) What a STUPID system!! Wish I could just program the VATS out of the system but I don't know of any shop who do that in my area.
  3. #18
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    You'll need a CCM, then. When you replace it you need to find out what key resistor value it is looking for. The CCM tells the PCM to ground the starter solenoid and turn on the fuel injectors when it sees the right key.
    EDIT: That's basically what you said above. I don't know how you 'interrogate' them, but since there's only 15 combinations to try you may be better off trying them yourself.
  5. #19
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    58
    7,894
    Quote Originally Posted by turbojimmy View Post
    I don't know how you 'interrogate' them,....
    ....waterboard them suckers. Good enough for CIA, good enough for you!
    turbojimmy likes this.
  6. #20
    BIGBEN11 is offline Cadillac Owners Member
    Automobile(s): 1985 fleetwood coupe & 1996 fleetwood brougham
    Aug 2012
    Knoxville
    15
    I had this problem on a past Fleetwood I owned and it was because I worked in a pizzeria and I got flour build up on my key around the chip after I cleaned it and put the key in and out of the ignition a few times while recleaning the key it worked
  7. Remove Advertisements
