Sign you might need a new waterpump..
Results 1 to 6 of 6
1985-1996 Fleetwood and Brougham Forum Discussion, Sign you might need a new waterpump.. in Past Cadillac Vehicle Discussion; After doing my waterpump last week (noticed a small puddle about the size of a quarter walking back to the ...
    Poda is offline Cadillac Owners Fanatic
    Automobile(s): 94 Fleetwood Base, 94 Fleetwood Livery-no vinyl top in sight
    Jan 2012
    Toronto, ON
    40
    286
    After doing my waterpump last week (noticed a small puddle about the size of a quarter walking back to the car in a grocery parking lot 5 mins from home, popped the hood and it was steaming from the weep hole), I just put the old one aside and forgot about it.
    Well, today I was cleaning up the garage, and before boxing it up to keep as a potential core later on (I have the room, so meh.. why not), I thought I'd take a closer look. I found this.. Missing cover, bearings and all.. Certainly explains some of the high pitch grinding sounds I was hearing a couple of weeks before but that had suddenly stopped. I pulled the front cover off, and the shaft is now so loose the impeller was hitting the sidewalls.
    Yeah, it's a miracle it didn't grenade on me - I certainly didn't have much time left on it and I lucked out on this one. The Cadillac Gods are smiling on me, considering I have an hour long commute to work each way.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,931
    Re: Sign you might need a new waterpump..
    My SS pump looked the exact same. It was leaking when I bought it, and I drove it for another couple of years before the seal finally blew out with a shower of coolant. Still on the same opti.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Ummm....aren't the bearings and cover in the cooling system inside the engine (they had to go somewhere)?
    j2rossit is offline Cadillac Owners Enthusiast
    Automobile(s): 85 FW Brougham, 68 Wildcat 'vert, 92 & 96 Roadmaster Wagons
    Jan 2011
    Southern Ontario
    934
    Wow, looks like one or two balls away from seizing. Lucky break.
    Sep 2006
    Ontario, Canada
    44
    7,931
    kevin, when it gets this bad, the pieces of the seal and bearings comes out the back, and falls on the ground.
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,390
    We had ours replaced years ago too and I believe it was not that bad as you showed in the pic lol . It's not worth taking the risk considering it's just perched above the distributor I believe and when it starts seepage things are not promising lol
  9. Remove Advertisements
