1992 Brougham needs to be lower
Results 1 to 9 of 9
1985-1996 Fleetwood and Brougham Forum Discussion, 1992 Brougham needs to be lower in Past Cadillac Vehicle Discussion; Need to lower by 2". Keeping stock tire size. How much will it lower if I replace the front springs ...
    Sheradan is offline Cadillac Owners Member
    Automobile(s): 1992 Brougham D'Elegance
    Mar 2010
    56
    27
    Need to lower by 2". Keeping stock tire size. How much will it lower if I replace the front springs with stock Impala SS springs? Will it give me the 2' I'm looking for?
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,620
    I think it would be very close to two inches if not right on.
    Mar 2010
    56
    27
    Re: 1992 Brougham needs to be lower
    Do I need to change the rear springs also?
    Jan 2008
    Minneapolis
    5,620
    If you want the rear to sit lower, you will have to replace the springs.
    Aron9000's Avatar
    Aron9000 is offline Cadillac Owners Master
    Automobile(s): Past: 95 Fleetwood, 91 Brougham. Now: 92 Lexus SC300
    Jul 2008
    Nashville, TN
    5,418
    Be sure to replace the shocks while you are at it. You won't be able to keep the level ride feature with the shorter springs, so just go with conventional shocks for the rear. If you want to keep the comfy ride, I've heard Monroe "Monro-Matic Plus" offer the best ride for a replacement strut.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    8,023
    One can keep the level ride with a lowered car, you need to adjust the sensor arm on the diff.
    Mar 2010
    56
    27
    Can I use stock shocks? Or do I need something different to compensate for less travel?
    Sep 2006
    Ontario, Canada
    44
    8,023
    You can use stock shocks.
    Aron9000's Avatar
    Jul 2008
    Nashville, TN
    5,418
    Quote Originally Posted by jayoldschool View Post
    You totally can, but IMO these cars are 20+ years old. Just replace them when you have the car apart. The fronts are really cheap, and so are the rears if you buy conventional shocks and do away with the level ride. Even air shocks that will work with all the level ride stuff are only about $100 to 150 a pop.
  12. Remove Advertisements
