Waterpump replacement - after the fact question
Results 1 to 7 of 7
1985-1996 Fleetwood and Brougham Forum Discussion, Waterpump replacement - after the fact question in Past Cadillac Vehicle Discussion; I was lucky enough this weekend to notice coolant just starting to seep from the weep hole. After figuring out ...
    Poda is offline Cadillac Owners Fanatic
    Automobile(s): 94 Fleetwood Base, 94 Fleetwood Livery-no vinyl top in sight
    Jan 2012
    Toronto, ON
    40
    286
    I was lucky enough this weekend to notice coolant just starting to seep from the weep hole. After figuring out that I had days if I'm lucky, or hours if I'm not, I parked the car and got to work getting parts and getting it done.
    Not too bad, and now that I've done one the next one will be a lot quicker when it comes off again in a couple of months for the heads and opti swap.
    This morning, I noticed a little puddle of coolant. Doh.. It turns out it's seeping from the heater core hoses at the pump. They're clamped on tight, but still seeping. Do the hoses need to be over both barbs on the metal tubes? Or just butt up against the second? Is there a trick to get these to stop leaking, at least until I get around to replacing them (which ideally, would be when the head/opti swap happens) - I was thinking a second set of clamps..
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,618
    Re: Waterpump replacement - after the fact question
    Another clamp may work but, if the hose is cracked near the end, you may not get it to stop leaking. Cracks and pinholes can be hard to see.
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    45
    1,845
    It's very likely the hose is ready for replacement. They get old and stiff. It continues to seal well until you disturb it. Then it is done.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,983
    The hose goes over both ridges. The clamp goes between the ridges.
    Jan 2012
    Toronto, ON
    40
    286
    Thanks guys - I put a second clamp on and so far so good. Will be sourcing new hoses for this weekend, and install them if the weather holds up.
    Sep 2006
    Ontario, Canada
    44
    7,983
    I wouldn't be so quick to replace the hoses. The materials are very good. I have actually never heard of someone losing an LT1 hose. Doesn't mean that it hasn't happened yet, but that's in 15 years of me driving them and reading more posts than can count on the various forums...
    Jan 2012
    Toronto, ON
    40
    286
    Fair enough.. I'll keep an eye on it over the next week or so. I did notice how pliable they still were though. Thanks for the tip Jay!
  10. Remove Advertisements
