Suspension Work
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By csbuckn
1985-1996 Fleetwood and Brougham Forum Discussion, Suspension Work in Past Cadillac Vehicle Discussion; I think I need to get a lot of stuff replaced. I know my suspension...shocks or struts, Im not sure ...
    igotaseed is offline Cadillac Owners Member
    Automobile(s): 1996 Fleetwood
    Jan 2013
    31
    4
    Suspension Work
    I think I need to get a lot of stuff replaced. I know my suspension...shocks or struts, Im not sure need to be done and I feel as though my ride isnt stable. When I turn corners it feels like a roller coaster ride! What do I need to do to restore my 96 Fleetwood to its proper ride? What will it cost in parts in labor?
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,619
    Re: Suspension Work
    Center link, tie rods and idler arm are the more common things. Find an alignment shop, they are usually the cheapest. Not just a place that does alignments but a place that does only alignments and suspension work.
    igotaseed likes this.
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,393
    Re: Suspension Work
    We had to replace bushings, tie rods , rear struts , S rod or something like this . I don't remember total cost but rear shocks were $200 as set .csbuckn is dead on
    Jan 2013
    31
    4
    Re: Suspension Work
    Thanks guys. I found a place that does a free suspension and alignment check. I'll have them write me a quote. Then I'll take it to another shop that says they will beat any written quote.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: Suspension Work
    If the parts aren't really worn out it is probably the shocks.
    Rick James is offline Cadillac Owners Fanatic
    Automobile(s): 1996 FWB
    Aug 2011
    Reston, VA
    46
    101
    Re: Suspension Work
    Quote Originally Posted by igotaseed View Post
    This is just an opinion so take it for what it's worth. If you are not doing your own work, your car will see quite a bit of shop time and you may want to build a relationship with a shop you trust.
    drmenard is online now Cadillac Owners Connoisseur
    Automobile(s): 95 FWB 81SDV 96 FWB 94 Fleetwood
    May 2003
    Massachusetts
    1,208
    Re: Suspension Work
    If you are feeling it most when you go around a corner , the first thing I would check is the sway bar links. They break all the time and let the front end sway and lift up when going around a corner.. they cost about $10 and are very easy to put in. If you look at it and its gone that's your problem. most of the time fall off after they break.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,492
    Re: Suspension Work
    I wouldn't trust a place that advertises they do free checks. Get a second opinion from a normal garage. Having someone look at it is the only way you're going to find out what's wrong.
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    Re: Suspension Work
    The center link and idler arm were bad on both of my Fleetwoods. They are the biggest contributors to sloppy steering and wandering on the highway and are very common wear items on these cars. Not too hard to replace and make a huge difference once you get new ones.
  12. Remove Advertisements
