Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: New used engine with loads of rust in engine!!!
    reelheavy is offline Cadillac Owners Fanatic
    Automobile(s): 1989 cadillac brougham
    Apr 2011
    maryland
    46
    130
    So after long days and night of swapping engines, me and my buddy finally get the rebuilt 307 in and it is a rust trap. When we first start it. The damn car almost over heats so we check the overflow jug and its orange and brownish looking. So then drain all the we antifreeze and flush the car about 4 times with distilled water, every time a nice wad of rust coming out. So we decide to run it with out a thermostat for a while so we can keep flushing it and hoping it would not over heat. So yesterday it was about 90 degrees outside we went for a 10 minute drive and by the time we got back to the garage the car was overheating.
    It is a used 307 with 5a heads and was rebuilt about a year and a half ago. Is there any chemicals we could use to try and get the rust out if the engine before I ship the car back to Philadelphia to the ******* who sold me the motor and get my money back??
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,618
    Any smoke out the exhaust? Are you still running water and no thermastat? Hows the fluid look now?
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: New used engine with loads of rust in engine!!!
    What condition is the radiator in? Is there enough airflow across the radiator? Clutch fan could be cricked and the radiator could have arterial sclerosis.
  5. #4
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,985
    Maybe try some CLR?
    The engine probably wasn't rebuilt. It was probably pulled from a car that sat outside, or, the engine was pulled, then sat out in the weather.
  6. #5
    Apr 2011
    maryland
    46
    130
    Quote Originally Posted by csbuckn View Post
    I just came form running the car, I am still running it without a thermostat, and there is no exhaust smoke, and I ran it for about 15 minutes after I refilled it with water and I popped the radiator cap off an the water is rust color with rust particles all in it.
    Quote Originally Posted by The Ape Man View Post
    Radiator is in good condition is was in way better condition than the one that came with the new engine. and there is plenty of airflow.
    Quote Originally Posted by jayoldschool View Post
    Maybe try some CLR?
    So with the CLR how should I do it? put it in and run it for a while then flush it??
  7. #6
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,854
    Leave the thermostat out, get a jug - or two - of Prestone cooling system flush. Nasty chemical. Change the water, add flush, drive. Dump it (don't ask about the EPA) and do it again. Pretty clean ???? Flush with good ol' garden hose fresh water. Don't worry about the distilled water thing with an iron block engine - Fill to proper cold level with 50/50 green coolant/water and drive - keeping a weather eye on coolant temps. Sometime later this summer, change the coolant again.
    50/50 coolant: One gallon of coolant, one gallon of water, a 2 quart pitcher. Pour 1/2 the water into the pitcher. Pour 1/2 the coolant into the water jug. Pour the pitcher of water into the coolant jug. 2 gallons of mixed coolant and a clean pitcher.
    Where are you in the great state of Maryland (If you can dream it, we can tax it !) ?
  8. #7
    Jan 2008
    Minneapolis
    5,618
    I'd definately keep flushing. Disconnect the heat core so it doesnt get clogged.
  9. #8
    Apr 2011
    maryland
    46
    130
    Quote Originally Posted by Submariner409 View Post
    Leave the thermostat out, get a jug - or two - of Prestone cooling system flush. Nasty chemical. Change the water, add flush, drive. Dump it (don't ask about the EPA) and do it again. Pretty clean ???? Flush with good ol' garden hose fresh water. Don't worry about the distilled water thing with an iron block engine - Fill to proper cold level with 50/50 green coolant and drive - keeping a weather eye on coolant temps. Sometime later this summer, change the coolant again.
    What the hell is Nasty Chemical?? And I am in southern Maryland. Waldorf, MD.
  10. #9
    Feb 2006
    56,854
    Cooling system flush is a caustic, rust-eating, oil-eating combination of poisons.
    How's your tobacco crop this year ??
  11. #10
    Apr 2011
    maryland
    46
    130
    oh ok cool. I am going to keep flushing her out, and hope like hell she's a keeper. And call the guy I brought it from tomorrow morning and get the real scoop on the engine because I believe it had to sit outside for a extended period of time.
  12. #11
    Apr 2011
    maryland
    46
    130
    After we spoke yesterday I put the garden hose to the radiator an ran the car flushing it for a good 2 hours, taking samples of the end result coming out of the radiator.
    So today while I was at work my mechanic was at the garage messing with the car, and he we ahead and put a Thermostat in it and some fresh coolant. And adjusted the carb. So I got home drove the car. It started right up, sounds like a new car, and went for a cruise, I drove about 30 minutes I came back to the garage popped the hood and their was no smoke coming from anywhere on the engine, The antifreeze was not bubbling, and the car did not sound weak while idling. So what is next? should I take it for a longer drive?, flush it? or what?
    http://us-mg5.mail.yahoo.com/ya/down...Inbox&inline=1
    That link is the picture of the samples I took while flushing the car. The bottle of the right was when I first started, the one in the middle was at the 1 hour mark. and the bottle on the left was the sample right before I finished.
  13. #12
    Feb 2006
    56,854
    Your link is dead, but you should now be OK.
  14. #13
    Apr 2011
    maryland
    46
    130
    just for clarity how can you tell if your engine is overheating?? and here is the picture.
  15. #14
    Apr 2011
    maryland
    46
    130
  16. #15
    Feb 2006
    56,854
    Your question: A REAL temperature gauge - the kind that actually moves in response to engine coolant temp changes. If your engine is supposed to use a 180 degree thermostat, it should run at 185 - 205 all day long - modified by any A/C (compressor) use and traffic conditions. If the car uses electric cooling fan(s) then they will determine the average coolant temps - within the thermostat band - that you see.
    50/50 coolant pressurized to 16 psi boils at 265 degrees, so somewhere around 240 - 250 is dangerously hot. True overheat occurs at boilover. GM allows a max 70/30 coolant/water mix, and that boils under pressure at 275 ...............
    The left bottle - do another flush before you refill with 50/50 coolant. Do a drain and refill in October. Not only does coolant mix raise the boiling point of the mix, it also prevents the rusty snot you're cleaning out.
  • You may not post replies
