Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: HELP wet floor - I thought this only happened to Jeeps
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,920
    So regarding my 91 Brougham, I just got home with the car and discovered the passenger side floor to be filled with water. No coolant, just water. Is a clogging of the AC drain common is these cars? The bottom of the heater box is wet so I'm assuming that's the problem.
    How do I fix it or is there something else we know to be a culprit?
    It's also been raining a LOT here but the car is pretty mint. I'd hate to think there was a leak somewhere.
    Ownership:
    91 Brougham d'Elegance 350
    95 Fleetwood Brougham
    01 Custom Deville DTS
    2011 CTS4 Luxury
    Memberships:
    National and regional Cadillac & LaSalle Club
    Proud Volunteer - Northstar Tuning Project
    Guinness World Records - Largest Cadillac Parade
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    40
    1,150
    Re: HELP wet floor - I thought this only happened to Jeeps
    You might have a leak/rust somewhere along the front window frame causing water to come in or firewall..
    SafariOne is offline Cadillac Owners Fanatic
    Automobile(s): 1981Cadillac Fleetwood Brougham D'Elegance Coupe m
    Mar 2008
    British Columbia
    392
    Along the windshield is a very likely spot. Do you have the sunroof on that car?? Roof drains??
  5. #4
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,920
    No sunroof and I'm pretty sure there's no rust. Where would I investigate for rust? Around the windshield? The car is a Florida car and has very little rust on it. Even the frame still has factory paint on it. The top does have a few small holes in it but I wouldn't suspect a breach in the vinyl to cause a leak
    So you don't think it's a clogged AC drain ?
    EDIT: just went out and did a little poking around. The cowl is clean and shiny with factory paint. There are no signs of rust anywhere on the cowl or near the windshield. I tried to stick my finger up under the bottom edge of the glass as much as possible and from what I can tell it's solid.
    I also poked the A pillars pretty good and they're also rock solid. No signs of rust that I can find anywhere.
    Ownership:
    2011 CTS4 Luxury
    Memberships:
  6. #5
    Johnny_Buchanan's Avatar
    Johnny_Buchanan is offline Cadillac Owners Fanatic
    Automobile(s): Allante '88
    Jun 2009
    Finland
    51
    143
    A pillar base and/or window frame rubber would be my guess. With Italian hardware I've seen several cases where tilted position of the car can flex body enough to let old rubber leak.
    -J
  7. #6
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,920
    LOL That's an interesting view. The car sits level during the rain. As I said this car doesn't have the normal signs of wear / age. It's been very well cared for. Rubber is soft and pliable, etc. I'm listening to what you're saying but I go out to check and that's not what I'm finding.
    Ownership:
    2011 CTS4 Luxury
    Memberships:
  8. #7
    Fleetwood472 is offline Cadillac Owners Fanatic
    Automobile(s): 78 Fleetwood w/ FI 472/ Switch pitch TH400
    Aug 2005
    240
    I had the exact same problem with my 78 Fleetwood. I could never find the problem until I got a crack in my windshield and took it into a well known quality window shop in town. When they pulled the windshield to replace it they noticed a ton of rust on the frame. This was not the original windshield on it. The previous owner had it replaced. After talking with the shop they said this is pretty common because usually what happens is when people have their windshields replaced some companies that do it scrape the paint on the fame when cutting out the windshield. They then reinstall the new one and it's fine for a while however that exposed metal will start to rust causing leaks which a lot of times you can't see but you'll end up with a ton of water in your dash. What a quality shop is supposed to do is touch up the scraped areas with paint to prevent future corrosion. What they ended up doing with my car was grind out all the rust and repaint it. Now when it rains it's good to go and I have zero leaks. If you checked the cowl and see no issues around it most likely your windshield is leaking. Do you know if the windshield was replaced in the past?
  9. #8
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,477
    It's probably from the windshield area. Even if there's rust you won't know it unless the windshield is pulled.
    Check around the heater box area too because there's gobs of sealer all over the place there and it's a lot easier to deal with that then the windshield.
  10. #9
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,920
    Hmm interesting. As far as I know the car is 100% original. So much to the point that I'm considering having it certified as a survivor. I didn't ask the previous owner but he only had the car about 18 months and didn't drive it much. It lived in a garage.
    Based on the condition of the car I have no reason to believe it's been replaced but who knows. Is there a way to tell by the markings on the glass somewhere?
    Ownership:
    2011 CTS4 Luxury
    Memberships:
  11. #10
    Jun 2003
    Canada
    6,477
    You should be able to tell by the markings on the windshield if it's original or not if you compare it to a car that is known for sure to have the original windshield. But even if it's never been replaced it can still leak over time and it's a lot more common with vinyl roof cars
  12. #11
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,920
    Hmm OK this isn't sounding good.
    EDIT: Ok I was just investigating the heater box. Now we're talking about the entire assembly that takes up about the whole passenger side of the firewall correct?
    The sealant you're referring to is what looks like a roofing tar that they use to seal that assembly to the firewall?
    That sealant has what appear to be dry rot cracks in a few places down the left side. Is it possible that this is the problem? Now I will say that I recently sprayed that area with a hose at the carwash but I'd hate to think the floor has been flooded since then.
    Ownership:
    2011 CTS4 Luxury
    Memberships:
  13. #12
    Jun 2003
    Canada
    6,477
    Yeah. The part the heater fan is mounted in. The sealant is on there in huge gobs that cover all the areas where that box touches the firewall. I don't know if all the sealant on it is necessary or not but there was tons of it I had to scrape off last year when I did the heater core on mine. If water can find it's way past that it can probably get into the car around the holes though the fire wall. I don't know how common it is for that to happen but like I said I think it's probably a lot easier to scrape that old stuff off and reseal it then it is to have to have the windshield pulled.
  14. #13
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,920
    Mines not gobby at all. It's actually nicely applied and looks as smooth as I'd expect
    Ownership:
    2011 CTS4 Luxury
    Memberships:
  15. #14
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    58
    7,894
    An easy way to check for where water is coming from is to spray the suspected area with aerosol foot powder. When wet again you will see where it ran from?
  16. #15
    Jun 2003
    Canada
    6,477
    Quote Originally Posted by codewize View Post
    The cowl parts in the wiper area with the plastic screening hide most of it. You might be able to see signs of it down behind the fender. All those big GMs had it.
  • You may not post replies
