Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Thread: HELP wet floor - I thought this only happened to Jeeps
  1. #16
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,920
    Re: HELP wet floor - I thought this only happened to Jeeps
    OK I'll keep investigating. I may pull that cowl screening of to look inside there.
    Ownership:
    91 Brougham d'Elegance 350
    95 Fleetwood Brougham
    01 Custom Deville DTS
    2011 CTS4 Luxury
    Memberships:
    National and regional Cadillac & LaSalle Club
    Proud Volunteer - Northstar Tuning Project
    Guinness World Records - Largest Cadillac Parade
  2. #17
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    My vote is for the HVAC housing to firewall seal as mentioned. Second suspected area could be clogged condensate drain.
  3. #18
    Robin Banx's Avatar
    Robin Banx is offline Cadillac Owners Enthusiast
    Automobile(s): 1983 FWB (Mac), 1981 SDV (Junkyard Dog)
    Dec 2007
    Vancouver, B.C. Canada
    725
    ^^ Yep.....that A/C housing seal has given me the same trouble on 2 Caddies and my wife's 81 Cutlass wagon. I can''t imagine why GM did such a crap job of sealing that gigantic hole. So......I'm with Ape Man on that one.
    Cheers.........R.
  4. #19
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,920
    Well in your case it was the 80's. The decade where American auto makers wanted to show the world how crappy and cheaply an automobile could actually be made. So they used the worst materials, the worst assembly methods and the worst labor they could find.
    And there you have American cars made in the 80's
    Ownership:
    2011 CTS4 Luxury
    Memberships:
  5. #20
    Robin Banx's Avatar
    Dec 2007
    725
    "EDIT: Ok I was just investigating the heater box. Now we're talking about the entire assembly that takes up about the whole passenger side of the firewall correct?" Not really. The first bad leaker I had was my 81 SDV from Sarant Cadillac in New York. Nice car but lots of probs to take care of. I too noticed the water on the passenger's floor. Towels were used for the first few weeks of this annoyance. Then anti freeze was added to the mix which had me thinking crusher .......... I gave in and had my rad shop replace the heater core. In doing so, he re-sealed the top cover on the engine room side of the A/C box and when he was done, all leaks vanished. Maybe I got lucky but maybe the top part is the problem.
    Cheers.......R.
  6. #21
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,920
    OK so the car has now survived 2 days of torrential downpour while sitting in the driveway. I intentionally didn't drive the car during his time because I want to be able to draw conclusions.
    After a TON of rain the floor and the underside of the heater box is dry. Bone dry.
    So, I'm not sure if that proves anything 100% but where is the AC drain on these? What needs to come apart to check it for clogs
    Ownership:
    2011 CTS4 Luxury
    Memberships:
  7. #22
    charley95 is offline Cadillac Owners Member
    Automobile(s): 91 brougham
    Sep 2013
    53
    Quote Originally Posted by codewize View Post
    The drain is a hole on the underside of the heater/evap. box on the firewall. It's easy to see from the underside of the car. There is no hose on the drain hole. I t is a big chore to remove the top half of the cover. I just removed mine and cleaned all the factory caulking and re-caulked with no leaks.
  • You may not post replies
