Trunk pull down question
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Like Tree3Likes
1985-1996 Fleetwood and Brougham Forum Discussion, Trunk pull down question in Past Cadillac Vehicle Discussion; How can i get my trunk to close without using the pull down motor? I want to just close it ...
    96LT1 is offline Cadillac Owners Member
    Automobile(s): 1996 Fleetwood
    Jul 2012
    40
    How can i get my trunk to close without using the pull down motor? I want to just close it and have it be flush where it should be, can i replace it with a latch from a car that didnt come with a pull down motor?
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,620
    Unplug it in the down position. Push the little lever until it goes down and then unplug it? Maybe that will work. The cars without it have a piece just welded on I think.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,495
    Re: Trunk pull down question
    Easiest way to keep it down is just unplug it and it'll work like normal. If it's broken and it won't go down by itself take it apart and twist it down by hand.
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    Why not fix it so it works properly? The part that usually breaks is (the paddle switch) is only $20. Otherwise, to get it in the same, flush position as the pulldown motor would have done you would have to slam it pretty hard every time.
    Angry Matt's Avatar
    Angry Matt is offline Cadillac Owners Enthusiast
    Automobile(s): (2) '81 FWBs, '86 Cutlass Supreme
    May 2009
    Limerick, PA
    38
    690
    Every one that I unplugged so far has to have been slammed several times to get it to shut right. It's really annoying, but I've never been motivated enough to fix them properly either.
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Quote Originally Posted by Angry Matt View Post
    Takes $20 and 5 minutes.
    Jan 2008
    Minneapolis
    5,620
    I forgot about that, you do have to slam it hard but you can always adjust the piece on the trunk lid and slide it down a little.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    It can be adjusted to close easily. My Fleetwood actually doesn't close all the way because I didn't screw it down far enough. I plan to tackle that issue this summer sometime.
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Quote Originally Posted by cadillac_al View Post
    Exactly. It can be adjusted to close easily, but easily is not as tightly as the pulldown motor would normally work. I've messed with a lot of them and the best solution is to make it work like stock. The parts are cheap and if it worked for 20-something years, fix it right and it will work for 20-something years more.
    YoshiMan's Avatar
    YoshiMan is offline Cadillac Owners Fanatic
    Automobile(s): 1975 Coupe Deville D'Elegance
    Oct 2012
    Denver, CO
    32
    261
    I was kind of disappointed when i discovered that my CDV is one of the rare cars that came without this option! ( at least i think it's rare, its the only big Cadillac i've personally seen without it) It's one less thing to break, but it always gets ooohs and ahhhs from people when you show them that a 37 year old car closes ANYTHING on it's own!
    bigm57ict and bigm57ict like this.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    Quote Originally Posted by YoshiMan
    My caddy doesn't have it....I figure that's a good thing....one less thing to break.
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    40
    1,150
    I don't have to slam mine at all. As soon as it latches, closes nice and smooth. So does the 78, the 79 doesn't have it..
    To answer question
    Have it closed first, disconnect battery, then open trunk, disconnect the plug, close trunk and reconnect battery.
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    That's the way my '96 and '94 were. When it works, you can hear the decklid creak when that motor pulls it down - it pulls down hard. Both of them leaked, too, when the pulldown was inop. It's so easy to fix I don't know why people go through the hassle of unplugging them and manually winding them to an optimal point. If you've eliminated potential issue of the wiring at the trunk hinge, it's probably the paddle switch. It literally takes 5 minutes to change. Part number 16629927.
  16. #14
    Jun 2003
    Canada
    6,495
    Quote Originally Posted by turbojimmy View Post
    Because they usually break at the worst time so you have to do that to get your trunk closed, then since you can close it it's not a very big priority to fix.
  17. #15
    Vladillac Khrougham's Avatar
    Vladillac Khrougham is offline Cadillac Owners Member
    Automobile(s): 1992 Brougham
    May 2013
    VA
    41
    60
    my grandfather would slam the trunk on his '02 Town car, now the trunk pull down no longer works (either by slamming or he disconnected it) but ever once in a great while the trunk will open while driving.
  18. Remove Advertisements
