Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: 1973 472 no start
    73cdeville is offline Cadillac Owners Member
    Automobile(s): 1973 deville
    Jun 2013
    6
    1973 472 no start
    Im having a pretty hard time trying to get this thing going again, recently had the carb rebuilt, distributor rebuilt, new plugs, wires, cap/rotor. Basically all the general maintenance stuff. The car ran fine, then one day started to cut out, and run really rough. thats when I took out the carb and had it rebuilt. I have good fuel going in, good spark, but for some reason It will not fire, and im at a loss for what more I can check.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: 1973 472 no start
    You have verified good spark and the accelerator pump is squirting gas? It should kick or something. Are the spark plugs getting too wet?
    Jun 2013
    6
    yes, its squirting gas, I pulled out a couple plugs and they seem ok, ive probably done this already several times just to make sure i didn't miss anything, but this really has me stumped.
    even emptied the tank, just make make sure there was no water in there.
  5. #4
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,022
    Fuel pump is good and no clogs in the fuel lines or tank pickup?
  6. #5
    Jun 2013
    6
    fuel pump is good, new filter no debris in it. maybe jumped a tooth or two on the timing chain?
  7. #6
    77CDV's Avatar
    Mar 2006
    Newbury Park, CA
    45
    10,022
    Possible. It only failed to start after the carb rebuild?
  8. #7
    Jun 2013
    6
    no it was previous to the carb rebuild, thats actually why i had it rebuilt because i thought it was the problem.
  9. #8
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,618
    Does it act like it wants to start or backfire? Spark, air and fuel is all it needs so you probably dont have spark. Have you tried gas or starter fluid down the intake?
  10. #9
    Feb 2007
    Maine
    55
    3,310
    If I was betting money, I bet on points and condenser every time. A lot of carbs get rebuilt because of bad points. It seems to me if there was spark, and the plugs aren't soaked, it should kick or backfire or something. Have you left your key on lately? I killed a couple coils back in the day by leaving my key on. One time the coil worked barely and ran horrible, and took me a long time to figure it out because that coil was new.
  11. #10
    Jun 2013
    6
    Alright, so basically it was a faulty condenser, i replaced it and the car starts and idles fine. now i have another issue, when i go to drive the car, it stumbles and pops under acceleration, then when i let off its fine. what could this possibly be?
  12. #11
    77CDV's Avatar
    Mar 2006
    Newbury Park, CA
    45
    10,022
    Exhaust backpressure.
  13. #12
    SafariOne is offline Cadillac Owners Fanatic
    Automobile(s): 1981Cadillac Fleetwood Brougham D'Elegance Coupe m
    Mar 2008
    British Columbia
    392
    Ignition coil or throttle position sensor issue.......
    Ignition coil or throttle position sensor issue.or distributor coil.
  14. #13
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Quote Originally Posted by SafariOne View Post
    There are no TPS units on 1973 472's.
  15. #14
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Have you checked dwell and ignition timing?
  16. #15
    Jun 2013
    6
    Quote Originally Posted by The Ape Man View Post
    Timing is set to 8 degrees btdc, im going to double check points gap, have not checked dwell yet.
  • You may not post replies
