1986 fleetwood broughm engine swap
Results 1 to 9 of 9
1985-1996 Fleetwood and Brougham Forum Discussion, 1986 fleetwood broughm engine swap in Past Cadillac Vehicle Discussion; Hi-presently own a 1986 Fleetwood broughm w/307-want to swap in a 462 or 500 for more power-how tough a swap ...
    shylilguy is offline Cadillac Owners Member
    Automobile(s): 1986 cadillac fleetwood broughm
    May 2013
    68
    Hi-presently own a 1986 Fleetwood broughm w/307-want to swap in a 462 or 500 for more power-how tough a swap is it -what trans can I use to handle the increased power and what type of rear end can I use to have low end torgue as well as having a decent cruiser for highway-finally do I need a different radiator to handle the increased cubes-thanx Bob
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    What is a 462 from?
    For a trans for a 500, you would need a turbo 400 or 4l80e with a controller
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,614
    If you can afford it, a 4L80e w/controller would be great behind a 472/500. No need to change the radiator unless yours is corroded or you plan on running ac a lot.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,565
    Re: 1986 fleetwood broughm engine swap
    Quote Originally Posted by cadillac kevin View Post
    What is a 462 from?
    What is a 462 from?
    that would be a Lincoln motor
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    A 77, 78 or 79 donor car would be the way to go. Otherwise there are a lot of $ needed.
    If I had a 307 car I would consider an Olds 403 and Grand National guts in the 200-4R.
    The entire job depends on what parts are available at reasonable cost.
    Fleetwood472 is offline Cadillac Owners Fanatic
    Automobile(s): 78 Fleetwood w/ FI 472/ Switch pitch TH400
    Aug 2005
    240
    I agree with Ape Man. Go with the 403. This way all of the 307 parts will bolt up for the swap. The 200-4R should be able to handle the 403 if you build it up a little. Those 403's are quick. I'd almost say they were faster than 77-79 cadillacs with a 425. I used to race around with my buddy who had a 77 buick electra w/403 and he could smoke my 78 fleetwood w/425. He got better gas mileage too haha.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    A 403 would be awesome but I haven't seen one for sale for a long time.
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by cadillac_al
    I've seen a few cars with it for sale, but they're usually too nice/ expensive to be an engine donor or so beat down that I wouldn't trust the engine.
    Feb 2005
    Southern NJ
    54
    2,096
    The price of scrap metal has made a lot of donor parts get melted down.
  12. Remove Advertisements
