Help - 1980 Coupe deville hard top clean up
Results 1 to 8 of 8
1985-1996 Fleetwood and Brougham Forum Discussion, Help - 1980 Coupe deville hard top clean up in Past Cadillac Vehicle Discussion; Hello forum members, I have a 1980 coupe deville that is currently at the body shop getting painted. My hard ...
    welhajjk is offline Cadillac Owners Member
    Automobile(s): 1980 cadillac coupe deville
    Oct 2010
    26
    I have a 1980 coupe deville that is currently at the body shop getting painted. My hard top is discolored and I am debating whether I should get it dyed or whether I should try cleaning it up myself first. Attached is a pic of the top. It might be a little hard to tell from the pic but it has this red-ish discoloration.
    Can anyone make a recommendation based on the pic. Is it faded to the point of no return or can it be cleaned up with the right products? and what would those products be?
    My top is in good condition other than the color. no rips/seams are good/no bubbles.
    thanks
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    39
    1,150
    Re: Help - 1980 Coupe deville hard top clean up
    You can try those vinyl cleaners that are sold at parts store and follow there recommendations on the product. Use a soft bristle brush to get into the grain and clean with terry cloth towels. Or get a new top in the same correct color and grain from smsautofabrics.com just submit the year make model and trim code.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,905
    That's not a "hard top", it's a vinyl top. Yes, it can be dyed, but it is not expensive to replace, and when you are getting the car painted is the right time to do it. Have the shop remove all the trim, take off the top, check to see if body work is needed around the trim/window area (rust often occurs here), and install a new top after the paint is done.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,612
    I also think you should replace it, mainly to unsure there is no rust issues as mentioned. When I was looking to get mine done, the prices ranged from 300 to 700 to get it done. Maybe I should tear the vinyl off my blue car to see what its like and whats all involved.
    Oct 2010
    26
    thanks jay for clarifying "vinyl vs hard top".
    I'm with u guys on replacing the top as its the proper thing to do. I was just hoping to keep the original top as is and just clean it up or dye it. I will try a vinyl cleaner but will most likely end up dying it for now. I'm sure after some years that will wear out and I will end ip having to replace the top.
    I've read online of some people using mr clean magic eraser on vinyl to clean it up. anyone have tried anything like that?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Clean what up? It's worn and faded, not dirty.
    Your new paint is going to make it look even worse. Replace it.
    Oct 2010
    26
    thanks for your help guys. will look into it
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    If you have stretched yourself too thin $ on the paint and are looking for a "get by" for a while solution I had good luck with just spray bomb clear satin to seal and bring color back to oxidized vinyl tops. Used to drive a lot of beaters in the 80's and most were 70s cars and almost all had bad vinyl tops!
    If you really care about the car...replacement is the way to go.
  11. Remove Advertisements
