The best brake shoes for 1995 Fleetwood
Results 1 to 9 of 9
1985-1996 Fleetwood and Brougham Forum Discussion, The best brake shoes for 1995 Fleetwood in Past Cadillac Vehicle Discussion; I am a bit confused - so many choices. Do I need riveted or bonded? Any particular part number to ...
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,117
    I am a bit confused - so many choices. Do I need riveted or bonded? Any particular part number to look for? I never bought brake shoes. Do they come in sets for one wheel, unlike pads?
    oops.. shoes not shows...
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,465
    Re: The best brake shows for 1995 Fleetwood
    Just like brake pads buy ones from a name brand and you'll be good. Let price take over from there. One set gets you both sides just like you're used to. I always replace the hardware at the same time - aka all the springs. Because they come in a kit and are cheap.
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,117
    Thanks, Brougham!
    I remember the original shoes were riveted, so I'll get ACDelco riveted ones. The last question. There are two sizes listed: 11" x 2" and 11.16" x 2.75 (2.81)". Which should I choose? The nominal inside diameter of the drum is 11.00". I guess bigger diameter shoes are for resurfaced drums? How about the width? Unfortunately, I cannot take off the wheels to check out.
    Thank you!
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    The 11.16" x 2.75" are the commercial chassis shoes. You want the 11" x 2"
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,117
    Quote Originally Posted by turbojimmy View Post
    Got it. Thank you!
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,187
    Re: The best brake shoes for 1995 Fleetwood
    If you ever had a bonded shoe come loose and lock up the wheel you would not have to ask if you should buy riveted shoes..Don't use bonded..
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,117
    Quote Originally Posted by drmenard View Post
    Yup, heard those stories. Looks like riveted shoes have shorter life though. As soon as the lining gets even with rivets, you have to replace the shoes.
    Jun 2003
    Canada
    6,465
    Yeah but even so, rear brakes don't do as much of the braking as fronts and last a long time. Quite often when bonded ones fail it's because of extreme heat, and riveted ones can also break apart under the same condtions. I can't even remember what I've been using. Mine is due for rear brakes this year, and drums. Double whammy.
    And you're welcome
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,117
    Okay, gents. Thank you. Will replace the hardware and clean the speed sensors while there as well. Have done the wheel cylinders a couple of years ago.
    Ordered these. I think they should be fine.
  12. Remove Advertisements
