89 Brougham Dlegance Heater Issues
Results 1 to 3 of 3
1985-1996 Fleetwood and Brougham Forum Discussion, 89 Brougham Dlegance Heater Issues in Past Cadillac Vehicle Discussion; Hi Guys, I bought a 89 Brougham with the 307 4bl, only has 58`000KM original, the only issue is the ...
    JLanzino's Avatar
    JLanzino is offline Cadillac Owners Member
    Automobile(s): 1989 Cadillac Brougham d'Elegance
    Feb 2012
    Ontario Canada
    26
    Hi Guys,
    I bought a 89 Brougham with the 307 4bl, only has 58`000KM original, the only issue is the heater not working, the old fan was burned out, so I replaced it, still not working, but if I ground the new fan it will work with car on or off, this shouldn't happen right?
    Where would be a good starting place, any advise? I want to plate it but I need to repair this heater to get the safety
    Thanks guys
    Robin Banx's Avatar
    Robin Banx is offline Cadillac Owners Enthusiast
    Automobile(s): 1983 FWB (Mac), 1981 SDV (Junkyard Dog)
    Dec 2007
    Vancouver, B.C. Canada
    730
    Re: 89 Brougham Dlegance Heater Issues
    Sounds like the heater control module (on top of the heater box in the engine room) has failed. I've had the same problem with both of mine (81 & 83). Can still be found in wrecking yards for about $25.00.
    Cheers............R.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    I'm confused? you have no blower or no hot air? Does it blow in the defrost mode? An inop. fan is usually the ground wire from the underhood power module. That ground wire goes to the center of the firewall by the hood bumper, Remove it and clean it. The motor itself screws into plastic and that screw can be loose, corroded preventing a good ground. If I recall the 307 had a hot water valve that requires vacuum to close it. Are the hoses to the heater core both hot?
